OBD1 or 2?? - Mustang Evolution
Old 07-20-2007, 11:23 AM   #1
95&modified's Avatar
OBD1 or 2??
OK, I've read all over the net on different ways to tell if my 95 has OBDI or OBDII but nothing I've seen makes any good sense. The write-ups contradict each other or are simply not correct. One example... "If you have an OBDII you will see it on the sticker under the hood". WRONG, my 97 doesn't have it. It has the sticker but no info. like on some makes. Anyway for sure how to tell?? Thanks
95&modified is offline   Reply With Quote
Old 07-20-2007, 02:55 PM   #2
hottcobra's Avatar
Re: OBD1 or 2??
all you have to do is look at the diagnostic port inside the car. if the port is square with a tap on each side it's OBDI if it's wider on the top than the bottom and the edges are rounded off than it's OBDII
Old 07-20-2007, 05:21 PM   #3
Re: OBD1 or 2??
When you say tap, you mean a connection right? Not an empty slot. Here are pics of both my 95 and 97. The grey carpet is 95, tan 97. They are built alike but have different "TAPs?" Sorry for the lack of focus, it's getting dark and it's raining.
ID:	17643   Click image for larger version
Old 07-20-2007, 08:39 PM   #4
hottcobra's Avatar
Re: OBD1 or 2??
sorry I ment tabs not taps. those are both OBDII connectors
Old 07-21-2007, 12:34 PM   #5
matthews.stang's Avatar
Re: OBD1 or 2??
The '94 & '95 V6 is ODBII.
The '94 & '95 GT is ODBI
All vehicles '96 and up are ODBII.
matthews.stang is offline   Reply With Quote
Old 08-05-2007, 06:02 AM   #6
Re: OBD1 or 2??
Thanks for the info. guys. I've been wanting to buy a tuner for my car but didn't want to waist my money on somthin that wouldn't work.
:Blah Blah: MODS, BBK 56mm TB, C.A.I., 3.73 with t-lock, MAC cat-back, Gt strut tower brace, Goldline springs, Accel 8mm wires, B&M stick, Red top, HO alt., Sony head unit with amp and sub, explode speakers. Rear seat delete, 2005 rims with spinners.:yawn
09:31 PM
