Front wheel bearings - Mustang Evolution
Old 02-15-2011, 08:15 PM   #1
V6 vert replacing my front rotors. Car has 97,000 easy miles on it. Should I replace the bearings at the same time. Presently the front bearing seem to be fine no noise or anything.
classman is offline   Reply With Quote
Old 02-15-2011, 11:17 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Front wheel bearings
i would just make sure to re-pack/grease them real good when u re-install them. better too much than not enough...lol.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
front wheel bearings 98mustang2007 1996-2004 Mustang GT 1 08-20-2010 10:19 AM
Wheel Bearings Mustang1804 1996-2004 Mustang GT 12 04-11-2010 11:05 AM
popping sound drivers front wheel edross 1996-2004 Mustang GT 15 06-21-2009 10:45 PM
Front Wheel Bearing Replacement 00vertstang Pre-2005 V6 Mustang 3 03-24-2007 09:42 AM
Wheel Bearings? Thomas91169 Mustang Wheels & Tires 6 09-06-2006 12:11 AM
08:19 AM
