Port and polish intake manofold - Mustang Evolution
Old 02-16-2011, 07:42 AM   #1
BigSteve305's Avatar
How much hp should I gain if I port and polish my intake manifold upper and lower? Also how much should a mechanic cost to do this job?
BigSteve305 is offline   Reply With Quote
Old 02-16-2011, 07:48 AM   #2
Re: Port and polish intake manofold
I don't think you'd see very much at all. Maybe 5. The heads really need to be done as well. That's where the power comes in at. And then even more with the cam. If you have a blower, you might see better gains. Id say go with the windstar intake for now. R u taking the parts on and off? Id say it'd cost around 300+. Not really sure.
tigerfan2771 is offline   Reply With Quote
Old 02-16-2011, 07:59 AM   #3
I was told I would gain more hp my boy did it to his crown Vic along with a x pipe and said he got 70 hp . So I should put new headers in first u say before I do that
Old 02-16-2011, 05:03 PM   #4
Titus Wadicus
svtlx's Avatar
70hp.... he might be exagerating a tiny bit.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-16-2011, 05:07 PM   #5
Not without some serious headwork. And ya do the exhaust first with long tubes so you can realize the full potential of any intake work
Old 02-16-2011, 08:29 PM   #6
Ya he does exaggerate a lil but he tuned it tune. I don't know too much about boosting hp I just know the more air, suck and gas your car gets the faster it will go. I have an exhaust already but I dont know what kind cuz when I bought the car it came with it. It's dual that's all I know I think it looks like an x pipe but don't know how can I tell. So I should get headers before I port n polish the intake manifold. When should I get a new throttle body ? What else should I do I just have dual exhaust and am cai
Old 02-16-2011, 09:25 PM   #7
70hp? lmao. more like 7. you could finish the exhaust with headers. but do it right and get long tubes. you'll need a new mid-pipe with those. pulleys are a good investment along with a tune. wait and do upper intakes, heads, and a cam at the same time. dont worry about a tb for quite a while. if you port the upper, you could just get your tb ported to match the inlet instead of wasting money. then youre ready for a blower or nitrous. its all about how much you wanna invest. and please slap your friend in the face for me
Port and Polish.... mystanghurts04 Pre-2005 V6 Mustang 5 06-12-2009 03:04 PM
PORT AND POLISH??? mrjones3133 Pre-2005 V6 Mustang 20 05-12-2009 11:30 AM
cost of port/polish? crazeflier07 Pre-2005 V6 Mustang 4 06-17-2007 05:06 PM
Port and Polish Choppa Pre-2005 V6 Mustang 2 03-16-2005 05:36 PM
Port and Polish jimmy_beaner Mustang Parts for Sale and Wanted 20 10-07-2004 04:31 PM
03:21 PM
