Cylinder 4 missfire - Mustang Evolution
Old 02-22-2011, 08:41 AM   #1
BigSteve305's Avatar
Cylinder 4 missfire
Ok I finally connected my car to a diagnostic computer and read p304 cylinder 4 miss fire check the plugs n wires even tho they are brand new also change the coil still same problem. I'm guessing I may have a bad fuel injector maybe or vacuum leak . Got. A 2000 v6 with 138,000 miles on it drives real good but has a lost of power and has a vibration and hesitation at low rpm on 1st gear and 2nd gear also my ac compressor does not work has a bad freon leak some one give me some advice on why I get cylinder 4 misfire
thanks
BigSteve305 is offline   Reply With Quote
Old 02-22-2011, 08:49 AM   #2
Joshy's Avatar
Try spark plugs. Mine did the same thing. I replaced spark plug and it worked fine. If it's not that u have bigger problems unfortunately.
www.petom.biz
Joshy is offline   Reply With Quote
Old 02-22-2011, 09:28 AM   #3
It's not the plugs there new i even switched the sparks plugs n wires with another cylinder and connected to computer again and still the same code came up . Still cylinder 4 misfire so it's not the plugs or wires
Old 02-22-2011, 09:34 AM   #4
Joshy's Avatar
It might be fuel injector if I remember correctly. Or maybe u need to replace the cylinder which would suck
www.petom.biz
Old 02-22-2011, 09:39 AM   #5
Ya that's what I was asking i think it's the fuel injector or a vacuum leak. To replace the cylinder it would be a big job. How much u think a mechanic would do that job for
Old 02-22-2011, 10:30 AM   #6
Joshy's Avatar
Oh idk 80$ maybe. Just an educated guess
www.petom.biz
Old 02-22-2011, 10:33 AM   #7
Joshy's Avatar
Maybe more like 100. Lol. Not totally sure.
www.petom.biz
Old 02-22-2011, 10:59 AM   #8
I hope it's only that much
Old 02-22-2011, 03:38 PM   #9
SaleenFiend's Avatar
Re: Cylinder 4 missfire
Have a compression test and leak down test done. You may have multiple issues that are possible. Are you a a good tech?
BTW you can just swap injectors like plugs
Old 02-22-2011, 03:41 PM   #10
Joshy's Avatar
And replacing cylinder is very expensive. I talked to a mechanic. But I'm guessing he's right and it's multiple little things
www.petom.biz
Old 02-22-2011, 04:45 PM   #11
How do u do a compression test and leak down test and no I'm not a good tech I'm learning bug my dad and friends are
Old 02-22-2011, 05:13 PM   #12
You will need a few tools. Talk to your dad's friend and let him show you. It would confuse you if I explained it on here. It's rather simple.
Old 02-22-2011, 05:15 PM   #13
MC770's Avatar
This guy does well explaining a leak down test
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 02-22-2011, 06:47 PM   #14
Mustangguy0202's Avatar
There's a compression gauge tool u remove the plug from the cylinder in question and hold that gauge in it... Unplug coil as to not turn over the car and have someone turn the key and let it turn about five times and read the gauge for the amount of compression your getting
Mustangguy0202 is offline   Reply With Quote
Old 02-23-2011, 07:01 AM   #15
Thanks a lot guys I'll try this with my dad this weekend
Old 02-24-2011, 09:40 AM   #16
What does the compression test check for?
Old 02-24-2011, 10:36 AM   #17
Compression in the cylinder. If there's low compression then u know u have a bad cylinder
Old 02-24-2011, 10:55 AM   #18
Which could either mean, piston rings, valves, valve seals, ect.
Old 02-24-2011, 12:22 PM   #19
Ok thanks and a leak down test is to see if u have a vacuum leak or is there more leaks that be can check?
Old 02-24-2011, 07:02 PM   #20
Do a compression test on that cylinder and see if you have compression.
Twinturbostang is offline   Reply With Quote
Old 02-24-2011, 07:07 PM   #21
By the way you are talking you have changed everything coil , plug , wire and still same thing. I'm saying it a dead hole. If you want to rule out the vacuum leak put a smoke machine on the car and see if you see smoke pouring out of anything . And if it comes out of that cylinder then you know you have a problem.
Old 02-25-2011, 09:15 PM   #22
I have the same problem in my 99 v-6. New coil pack, wires, plugs, injector cleaner, etc. It's a well maintained car but this problem is driving me crazy.
mightymav72 is offline   Reply With Quote
Old 02-25-2011, 09:49 PM   #23
Do a compression test on that cylinder. Pretty sure you will find that you a dead hole
Old 02-25-2011, 09:56 PM   #24
Stuff like that could happen to anyone even if motor is well maintained. You might have drop a seat on the valve
Old 02-25-2011, 09:59 PM   #25
Just be glad you don't have a 5.4 motor. Your just driving down the road a boom you blow a plug throw the motor.
Cylinder Misfiring? Jeremym831 1996-2004 Mustang GT 4 02-05-2008 01:12 PM
New Cylinder Heads V6Polish Pre-2005 V6 Mustang 5 06-24-2007 02:28 PM
P301 Missfire Cyl. 1 BruThru2002 Pre-2005 V6 Mustang 3 06-06-2007 08:40 AM
Missfire Cylinder 1 BruThru2002 Pre-2005 V6 Mustang 12 05-15-2007 04:36 PM
92 four cylinder problem Ponyboy86 Pre-2005 V6 Mustang 11 03-23-2005 02:45 PM
01:40 AM
