Manual Transmission Install Question - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 02-22-2011, 05:36 PM   #1
dino.999 is unknown around these parts
96 V6 5spd with synchros going bad, thinking about taking a chance with a used tranny.
Reading my Chilton I remove the tranny first then the bell housing and clutch assy, re-install in reverse order.
Does this mean I can just swap out the tranny to make sure it works then replace the clutch later???
Dean
dino.999 is offline
Old 02-23-2011, 07:32 AM   #2
Terminator Owner
SpectorV is just getting started.
Re: Manual Transmission Install Question
being that your mustang has a T-5 manual trans you can take the trans out without the bell housing, which is a nice thing to do. Other Mustangs cant do that lol.
Technically you can slide it out and put another one in without removing the clutch.
since its a 99 up its a digital speedo gear so a pre 99 wont work without swaping tail shafts with your newer one. Just FYI and some T-5s have different gearing~ so get one from the same type of car, any 99-04 v6 should work.
SpectorV is offline
Closed Thread
Manual to Auto transmission conversion for 03 Cobra...... drusmith 1996-2004 Mustang GT 20 12-19-2010 08:34 PM
Manual transmission Ninethourpm Pre-2005 V6 Mustang 7 03-23-2010 08:01 AM
Manual Transmission Fluid Change Gray Ghost 1979-1995 Mustang GT 0 04-11-2009 06:51 AM
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
manual transmission question flyingburritoz Classic Mustangs 1 11-19-2007 08:10 PM
01:40 PM
