02-25-2011, 07:24 PM
#1 | | Registered User
| H pipe with or without cats?
I put in true dual Spin Tech Pro Streets 3 weeks ago, but made 1 mistake. I didn't put in an H pipe. The exhaust sounds nice and loud, with a good rumble from 0-50, but a little raspy at the higher RPM's. And now that I put in a 4.10 rear, she runs about 2700-2800 RPM's at 70. Everyone says I should put in an H pipe, it will give it a deeper rumble. My question is twofold. 1, cats or no cats? I've heard no cats smell bad and add to the raspy sound. Also heard need cats for V6 back pressure. 2nd I had a muffler Guy tell me all he would have to do is place a pipe between my existing pipes and it will be the same as an H pipe. Is that right? Or should I actually buy an H pipe? Please send me all your advice and opinions. They will be greatly appreciated, Vic.
02-25-2011, 07:32 PM
#2 | | Evolution's Finest
I had a pipe welded in, in sounds much better than it did without it, I still have my cats too.
Sent from my iPhone using Mustang
Just because something "can" be done, does not mean it should be done....
02-26-2011, 12:24 AM
#3 | | Registered User
Without all the way. Sounds really good. In my opinion
02-26-2011, 12:34 AM
#4 | | Registered User
| Re: H pipe with or without cats?
depends on the diameter of the pipe and the aftermarket pipe. Not sure what it is on the stock pipe but if its the same size as an aftermarket you could prob just gut your cats instead of welding a piece of pipe between them. but I'd say do it right and just get an off road h pipe if your looking for a deeper sound, x pipe if your looking for a little more power
__________________ |
02-26-2011, 12:50 AM
#5 | | Registered User
| Quote: |
Originally Posted by vnicastro I put in true dual Spin Tech Pro Streets 3 weeks ago, but made 1 mistake. I didn't put in an H pipe. The exhaust sounds nice and loud, with a good rumble from 0-50, but a little raspy at the higher RPM's. And now that I put in a 4.10 rear, she runs about 2700-2800 RPM's at 70. Everyone says I should put in an H pipe, it will give it a deeper rumble. My question is twofold. 1, cats or no cats? I've heard no cats smell bad and add to the raspy sound. Also heard need cats for V6 back pressure. 2nd I had a muffler Guy tell me all he would have to do is place a pipe between my existing pipes and it will be the same as an H pipe. Is that right? Or should I actually buy an H pipe? Please send me all your advice and opinions. They will be greatly appreciated, Vic. | I have no cats and it sounds pretty good. I have BORLA catback stingers too though. I don't notice any bad smell.
02-26-2011, 02:18 AM
#6 | | Registered User
Get a of road x pipe.
02-26-2011, 04:53 AM
#7 | | Evolution's Finest
Be different, weld an s pipe in there and call it a day!
02-26-2011, 07:00 AM
#8 | | Registered User
| Re: H pipe with or without cats? Quote:
Originally Posted by Project Pony Be different, weld an s pipe in there and call it a day!
Sent from my iPhone using Mustang | ?
02-26-2011, 07:09 AM
#9 | | Senior Member
| Quote: |
Sent from my iPhone using Mustang | What the **** is an s-pipe?
02-26-2011, 07:15 AM
#10 | | Registered User
Originally Posted by sno4life What the **** is an s-pipe? | He's trying to be funny.
02-26-2011, 07:17 AM
#11 | | Registered User
BTW you can just have a pipe welded in place.
02-26-2011, 08:08 AM
#12 | | Evolution's Finest
Or am I? But yes you can just have a pipe welded across for very cheap. About 20-50 bucks depending where you take it, 50 would really be on the high side since it's just a small straight pipe, and takes less than 10 minutes to do.
