Thud in rear diff - Mustang Evolution
Old 02-25-2011, 07:35 PM   #1
Project Pony's Avatar
Thud in rear diff
I noticed today that shifting into 2nd from 1st I hear a slight thud from the rear end, any thoughts?
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 02-25-2011, 07:36 PM   #2
Re: Thud in rear diff
U Joint?
93CobraGuy is offline   Reply With Quote
Old 02-25-2011, 08:12 PM   #3
Originally Posted by 93CobraGuy
U Joint?
Lolololol!!
sno4life is offline   Reply With Quote
Old 02-26-2011, 06:54 AM   #4
SaleenFiend's Avatar
Originally Posted by 93CobraGuy View Post
U Joint?
Could be a u-joint, but I do notice this is common espescially on IRS equipped Mustangs. Tends to be a decent amount of slack b/w the driveshaft/rearend/transmission.
Old 02-26-2011, 08:05 AM   #5
I'll get under there and check things out.
[SIGPIC][/SIGPIC]
Old 02-26-2011, 11:39 AM   #6
From your posts, it sounds like you are knowledgeable enough to know how to check U joints. Hope you find the culprit!
Old 02-26-2011, 04:32 PM   #7
I know my way around. I just rebuilt the rear end in my wife's explorer, and know that banging around back their is no good. Its coming from the diff. I had my son stick it in first while I was laying back there listening and it is something in their making a thud. I am tired of the smell of gear lube and don't want to tear it apart, but I may have to.....or stick an 8.8 in it.
[SIGPIC][/SIGPIC]
Old 02-26-2011, 04:39 PM   #8
Thuds are no good for sure. Hell, if it were me, I'd just throw the 8.8 in and call it good.
Old 02-26-2011, 05:19 PM   #9
I'm going to keep my eyes out for an 8.8 with 3.73's and be done with it
[SIGPIC][/SIGPIC]
Old 02-26-2011, 05:31 PM   #10
Good call, you won't be disappointed.
Old 02-28-2011, 09:10 AM   #11
as all have said above also check the bushings on the lower control arms if the car is older~ I doubt thats it but if they are worn the rear can move front/back more and that could be it. Make sure the bolts are in all the way and not getting lose as well for upper and lower control arms.
Rear Diff is leaking, OH NO!!!!!!!!!!!!!! drusmith 1996-2004 Mustang GT 13 02-21-2011 03:55 PM
Need a new Diff which is best? Uprnewedge 1996-2004 Mustang GT 0 02-11-2010 09:06 AM
89 5.0 gt_ rear diff. Cutting into cover whiteboy.302 1979-1995 Mustang GT 3 09-04-2009 10:31 AM
Rear diff oil change help ctstang Pre-2005 V6 Mustang 1 10-28-2006 06:50 PM
is there much diff??? v6white98 Pre-2005 V6 Mustang 13 12-25-2003 03:15 PM
09:47 PM
