fog light question? - Mustang Evolution
Old 07-24-2007, 07:19 AM   #1
MoOn-BaBy's Avatar
Question fog light question?
I recently bought a set of aftermarket fog/driving lights to install, and when my husband took to covers off the bumper we noticed that the factory wiring harness is there but when we hooked up the lights to that wiring they wouldn't come on. Has anyone else noticed that their cars had the wiring? And is there something else needed to make that wiring work? We also popped out the coin tray to see if the wiring was there for the switch but it is not.
MoOn-BaBy is offline   Reply With Quote
Old 07-24-2007, 08:54 AM   #2
Re: fog light question?
To my knowledge the only 94-04's with factory fog wiring would be pre 96 (or 97) cars. You probably dont have a fuse in the fuse panel for the fogs nore the factory on/off switch so you might have to do some wiring.
Old 07-24-2007, 09:02 AM   #3
hottcobra's Avatar
on a GM you have to install the fuse, factory switch, & reprogram the BCM to install a factory fob light add on
Old 08-22-2007, 10:09 AM   #4
If it's a "94 or '95 you need to put a relay(same as the others in the fuse box) in and a fuse in the fog light socket. Then there should be a connector in the center console for the switch.
xsvspd is offline   Reply With Quote
Old 08-25-2007, 06:06 AM   #5
Mine is hard wired into the regular head lights so they come on at the same time. This made it easier to install
nmaraijko is offline   Reply With Quote
Old 08-25-2007, 01:08 PM   #6
I liek gramer
WhiteStang99's Avatar
I would think you could wire them into the parking lights wire like I did with my gauges..
There may be some obvious reason why you can't, but that is just a thought.
Old 09-01-2007, 12:01 AM   #7
Region: New Hampshire
Send a message via AIM to Smokedya95stang
94-95 v6's we're prewired.
The foglights wont turn on just by turning on your headlights
You need a relay that gets placed in the engine bay fusepanel, and a factory switch.
you wont see the plugs just by removing the coin holders i actually removed the box inside the armrest it was just a couple of screws and its alot easier to work with everything. I think you'll probably see like 3 harness's tho and i forget which one. If i recall correctly there was different color plugs i think its grey. haha.
-Charles
Smokedya95stang is offline   Reply With Quote
Fog light help? USMC Gypsy Pre-2005 V6 Mustang 4 10-20-2008 10:53 PM
Fog light help!!! kcfan_2004 General Mustang Discussion 9 05-07-2008 06:48 PM
New Fog Light Question 95v6 Pre-2005 V6 Mustang 0 01-29-2008 03:52 PM
fog light question jimmy_beaner Mustang Audio & Video 5 05-29-2006 03:29 PM
fog light help jahizzi Mustang Audio & Video 8 01-17-2005 06:00 PM
02:19 PM
