Need Horn Help - Mustang Evolution
Old 02-28-2011, 06:42 PM   #1
obxdude018's Avatar
Need Horn Help
This is important to fix since I can't pass inspection without a horn, my horn stopped working a while ago, I know its not the horn since I bypassed the relays to test it, where is a good place to test, I know of 2 relays, 1 in the BEC, and the other mounted above the radiator. Also, when pushing the horn button, a one time click would be heard from the relay in the BEC.
obxdude018 is offline   Reply With Quote
Old 02-28-2011, 06:46 PM   #2
Swap that relay with one just like it and go from there. If that doesn't work you're gonna need a test light. Key on, relay should have two hot leads. It's clicking which means that the horn button is working. It's either bad relay or the other hot lead has a blown fuse.
Alscobra is offline   Reply With Quote
Old 02-28-2011, 07:31 PM   #3
Re: Need Horn Help
It could be like my car. Clock spring is tore up, too lazy to pull it apart.
Does the car have cruise buttons as well? If so...do they work.
Old 02-28-2011, 07:32 PM   #4
obxdude018's Avatar
Re: Need Horn Help
Cruise control works just fine, I can push the button and hear the relay click
Old 02-28-2011, 07:36 PM   #5
The horn button is good. It only supplies a ground to the relay. Did you swap relays?
Old 02-28-2011, 07:36 PM   #6
Re: Need Horn Help
Not the clock spring then. Nvm...
Old 02-28-2011, 07:41 PM   #7
obxdude018's Avatar
Re: Need Horn Help
Going to switch some of the relays around tomorrow and see if that works.
Old 02-28-2011, 07:44 PM   #8
There should be another relay just like it. If it fixes it, make sure you swap them back and replace that relay. Mark the horn relay before you swap it just in case you loose track of the bad one.
Old 03-01-2011, 03:41 PM   #9
obxdude018's Avatar
Re: Need Horn Help
Moved around some relays and nothing happening, I moved the relay for the defroster into it and just a clicking noise, I moved another one and no noise from that one.
Old 03-01-2011, 03:46 PM   #10
You already said that you jumped the pins and the horn blew. Correct? If that is correct, you need a test light. Cheap autozone job will work. Two pins where your relay plugs into should be hot. Pretty sure one is not. You prob have a blown fuse going to one of the leads. Check your fuse panels before anything.
How To Hook Up A Horn mustangondubs Pre-2005 V6 Mustang 3 01-31-2008 10:22 AM
01 GT Horn Relay lowering kit 1996-2004 Mustang GT 8 01-10-2008 07:41 AM
'65 Horn issues Ken Classic Mustangs 4 04-11-2006 07:23 AM
Air Horn Fun!!! sctalbott The Bar 6 06-09-2004 11:51 AM
3am fog horn Monkey The Bar 2 08-03-2003 08:00 AM
01:16 PM
