Automatic trany - Mustang Evolution
Old 03-03-2011, 07:56 AM   #1
BigSteve305's Avatar
Automatic trany
I have a automatic tranny and I want to know if putting o/d off bad for the tranny and or using the 1st and 2nd gear then put it on d to go to third bad for the tranny. I have a lot if more power when I start off on 1st gear then shift to 2nd then 3rd gear put it on drive . If I do this a lot could I mess up my tranny
BigSteve305 is offline   Reply With Quote
Old 03-03-2011, 07:58 AM   #2
Re: Automatic trany
when you manually shift the car it wont add to the car at all, it wont make any more power. Basically all you are doing is telling the car where to shift at.
With a good tune for the car leaving it in drive will yield better performance results as the car can then shift better than you can manually.
I used to want to do this with my old 97 V6... but it didnt help I ended up realizing I just really wanted a manual transmission and finally got one in my next car lol.
Some say manually shifting will hurt the car, not sure why really~ and overdrive is just another gear, nothing special so leaving it off just means you wont shift into 4th gear.
Old 03-03-2011, 08:03 AM   #3
When I shift 1st n 2nd gear manually I feel a lot more power when I floor it on drive from being stop I don't even peel out maybe just for like a second when I floor it on 1st I peel out for 3 or more seconds and it picks up faster and 2nd too. When I have it on drive 1st n 2nd is really slow doesn't feel like I'm not hitting the gas the rpm doesn't even go up prolly goes to 4,000 rpm
Old 03-03-2011, 08:04 AM   #4
Ya I defiantly need a tune. How r those self tuners u can buy off of am
Old 03-03-2011, 08:29 AM   #5
Joshy's Avatar
It still shifts though. It's a safety feature and I has he exact same power.
www.petom.biz
Joshy is offline   Reply With Quote
Old 03-03-2011, 01:31 PM   #6
It doesn't have anymore power bud. Sorry
Built 2 Last
Old 03-03-2011, 02:07 PM   #7
Well when I put it on drive it's slow then when I shift 1st n 2nd manually it's faster u can feel a big difference
Old 03-03-2011, 02:49 PM   #8
Re: Automatic trany
I would say go to the track and run it back to back and see which one works better for you
Old 03-03-2011, 02:55 PM   #9
Good idea. Then you will have a real number to compare to not just the butt dyno
Built 2 Last
Old 03-03-2011, 03:45 PM   #10
Re: Automatic trany
To eliminate any guessing buy an SCT tuner from American Muscle or VMP Tuning.
Either does great work regarding custom tunes and your auto will benefit from it immensely. It's definitely worth the ~$400 if you have an auto.
97 v6 3.8 automatic calizdbomb Pre-2005 V6 Mustang 3 10-23-2010 03:25 PM
2005 2006 2008 2009 v8 Mustang Manual Trany Swap 5 for a 6. redracer500 General Mustang Discussion 0 07-28-2008 12:12 PM
Automatic gearing ranebowcyxx Pre-2005 V6 Mustang 4 05-30-2006 09:03 PM
Automatic shifter help!!!! PonDog15 Pre-2005 V6 Mustang 15 11-30-2005 11:19 PM
99-04 Automatic transmission Dark02Pony 1996-2004 Mustang GT 4 11-21-2005 02:09 PM
10:27 AM
