some neat projects for your viewing - Mustang Evolution
Old 10-30-2003, 06:52 PM   #1
RGR
Send a message via AIM to RGR
The posts from a Split Port crossover tube, These little things are
responsible for cutting ~205 CFM! They are a bit taller, the bottoms
break off when they are removed.
The roughed-in TB opening, I'm thinking 65mm or more.
It was out of round when I got it, someone decided to play with the core
The top. This thing is RUFF inside, but luckily just the bottom of the
crossover, the top and sides are pretty smooth. The rear plug is removed too.
Blower Ported PI heads (4.6 mod motor)
Now, the real teaser!
What would YOU do???
I got other stuff but I gotta get off of here...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 10-30-2003, 07:15 PM   #2
Rob, is there anything you can do with this section?
looks like it could possibly open up a lot more flow to the closest side runners if the only way to get at them wasnt around this.
or not.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 10-30-2003, 07:51 PM   #3
Danger Dude's Avatar
Damn Robert some wild stuff. you are a man with a die grinder and has skills using it. do you also have a table band saw
Old 10-31-2003, 05:00 AM   #4
RGR
Do you mean the runners under that Mike, or that area itself?
The whole side can be cut out... but that is not needed. I have
really long carbide and can really port the heck out of those
intakes.
As for that area of the crossover tube, I'm going to fill in that
depression there, and get better flow. Stupid divot
I do not have a table bandsaw Corey, but I plan on getting one.
My welder has one, I've used it before.
Old 10-31-2003, 06:35 AM   #5
I think I was looking at it the wrong way....n/m
Rob, for those of us who dont have a PCV anymore would you be able to remove that inlet tube on top and plug it up? ie to have a cleaner upper.
New Hottness
1999 V6 5-speed
Wrecked
Old 10-31-2003, 06:40 AM   #6
Hey stangin99 what do you have for the the evacuation of crankcase pressure filters or what. does the 99+ have a PVC system like the 94-98 with one going to the intake tube and the other to the lower area of the upper intake ????
Old 10-31-2003, 07:52 AM   #7
tire's Avatar
Send a message via AIM to tire
Re: some neat projects for your viewing
Methinks I know.
tire is offline   Reply With Quote
Old 10-31-2003, 10:18 AM   #8
Hey Robert a U shaped plenum with the crossover in the front like the SS camaro with a twin duct system going down to 2 each ram air horns
Old 10-31-2003, 12:49 PM   #9
I have breathers on both valve covers yea.
One PCV inlet is into the intake tube. The other you can see on Robs one pic of the top of a 99+ intake. Its the shiney metal pipe in the middle of it all.
New Hottness
1999 V6 5-speed
Wrecked
Old 11-01-2003, 05:50 AM   #10
Send a message via Yahoo to plstktnkr2
hey RGR what size those valves on the heads we are going to do?(big valve heads for my 3.8/4.2)
they are for an '87 engine
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 11-01-2003, 08:14 AM   #11
RGR
For the carbed deal? It will be 1.84/1.50 (stock is 1.78/1.45)
Old 11-03-2003, 10:43 AM   #12
intakes.
depression there, and get beter flow. Stupid divot
My welder has one, I've used ot before.
Welded in divet = good : )
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
it says there 16 viewing now who are you 2007STANG Pre-2005 V6 Mustang 10 08-07-2009 03:17 AM
I can never have enough projects... Kiljosh Pre-2005 V6 Mustang 2 10-02-2008 07:56 PM
For your Viewing Pleasure Thomas91169 Pictures and Videos 23 08-24-2006 09:31 PM
Hello to all you Viewing Guests out there surfing, come in here! SpectorV The Bar 20 05-02-2006 01:22 PM
11:28 AM
