Rpm problem - Mustang Evolution
Old 03-07-2011, 05:30 PM   #1
Rpm problem
I have a 95 mustang 3.8, when I go up hill and press the gas to go, the rpms go up to 1700 then, will the pedal pressed in the same amount as before, the rpms slowly go down to 1100 for some reason.... The belts are a little loose ( i think) and need replacing, could this be my problem???
Mgodfrey is offline   Reply With Quote
Old 03-07-2011, 05:50 PM   #2
Auto or 5 speed....if it's a 5 speed your clutch is cooked. If it's an auto you got real problems
Built 2 Last TTT
Old 03-07-2011, 05:53 PM   #3
Auto, what do you think it is? Cause I had the engine rebuilt by a professional, and no other problems?
Old 03-07-2011, 06:01 PM   #4
It only does it when I'm going up a big hill at like 20, 25 mph
Old 03-07-2011, 06:10 PM   #5
That's a tranny issue. Torque converter maybe....I would get it looked at because if the torque converter is slipping that much it will generate alot of heat and heat kills auto trannys. With any luck a tranny guy will chime in here and help. I am just giving you my best guess
Built 2 Last TTT
Old 03-07-2011, 06:12 PM   #6
Ya I've had problems with my tranny, slipping, starting in second gear, and locking up going downhill in over drive so ya
Old 03-07-2011, 09:33 PM   #7
Titus Wadicus
svtlx's Avatar
Re: Rpm problem
you definatley got trans issues.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-20-2011, 05:32 PM   #8
What Do you think is wrong with the tranny?
Old 03-20-2011, 05:34 PM   #9
Gender issues are always gonna be a problem.
Alscobra is offline   Reply With Quote
Old 03-20-2011, 05:38 PM   #10
Transmission not transsexual
Old 03-20-2011, 05:40 PM   #11
Oh ok. My bad. Hahaha
Old 03-20-2011, 05:43 PM   #12
Lmao Al....you're too much
TTT
sno4life is offline   Reply With Quote
Old 03-21-2011, 07:50 AM   #13
Titus Wadicus
svtlx's Avatar
Re: Rpm problem
from what you described, it sounds like a a bad torque converter. the lock-up is staying engaged at the wrong times.
take off RPM NotoriousSPG Pre-2005 V6 Mustang 3 08-12-2006 07:48 AM
RPM Problem whitev6stang03 Pre-2005 V6 Mustang 6 01-20-2006 05:52 PM
Peek hp rpm? SeadudeRXP Pre-2005 V6 Mustang 12 12-12-2005 01:53 PM
RPM drop Murph00 Pre-2005 V6 Mustang 12 07-16-2005 12:32 PM
RPM problem Dave Pre-2005 V6 Mustang 22 10-27-2003 10:55 PM
12:06 AM
