Cobra Taillights Amber Turn signals - Mustang Evolution
Old 03-10-2011, 07:56 PM   #1
I recently purchased my 02 convertible and have been reading up on many of the issues and modifications.
In perusing the Mustang Articles above, I came upon the Brandon Hughes article on installing the 99-01 taillights into the regular taillight mustang. I really like this version but I've seen many comments that its a personal taste thing.
Now for the difficult part. The lights aren't available from Ford or any of the vendors anymore. Further complicating matters is that they have to have the harness as well as its different and needs to be spliced in according to the article.
So, now the search is on for the lights. Looks like used is the only way to go. Also, there are very few harnesses to be had according to Ford. Three for the right and there was one remaining for the left side in the entire country. The lights certainly are not available new and I wouldn't want to see what they cost in any case.
I did talk with a used Mustang guy and he said that many of these lights go overseas since the amber turn signals are mandatory there. He sold and does sell all he has.
vertrx7 is offline   Reply With Quote
Old 03-10-2011, 10:49 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Cobra Taillights Amber Turn signals
u try ebay?.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-11-2011, 06:56 AM   #3
Nothing on ebay. Completely dry...at least for factory lights. Plenty of aftermarket stuff...
Old 03-11-2011, 08:15 AM   #4
USAF_stang's Avatar
check your local junkyards...and if they aren't in the actual car itself they sometimes take stuff out of the car and shelve it inside their shop. Just ask around.
USAF_stang is offline   Reply With Quote
Old 03-11-2011, 08:51 AM   #5
ebay has them normally, they are a bit more~ but its a personal preference thing.
Old 03-11-2011, 09:53 PM   #6
Finally found some, not cheap, had to travel a bit of a distance. But actually found two sets. So they are out there. Not easy to locate though.
Replacing turn signals ThaBear14 2005-2010 Mustang GT 15 12-09-2009 08:35 PM
SN95 corner lights/turn signals Otlaw80 Mustang Parts for Sale and Wanted 3 09-01-2009 11:43 AM
Green Turn Signals, an illegal immigrant thang?? Rick0636 The Bar 28 10-04-2003 11:27 PM
Turn signals robert0803 Pre-2005 V6 Mustang 7 09-30-2003 11:52 PM
09:24 AM
