i start the engine and it runs for 5 seconds but then stalls out - Mustang Evolution
Old 03-11-2011, 02:58 PM   #1
i am getting fuel pressure...
the spark plugs are in...
the firing order is correct....
the starter alternator and relay box are tested and in good working order so what is the problem?
Pascullon is offline   Reply With Quote
Old 03-11-2011, 03:13 PM   #2
Project Pony's Avatar
Is it throwing any codes?
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-11-2011, 03:20 PM   #3
Fuel filter...just guessing here
Built 2 Last TTT
Old 03-11-2011, 03:37 PM   #4
Re: i start the engine and it runs for 5 seconds but then stalls out
well when i depress the stem on the fuel rail a crap load of my new gas comes spewing out can it still be the fuel filter? and yes it is throwing a cel but idk what the numbers are till tuesday
Old 03-11-2011, 03:38 PM   #5
Well if fuel is good I would guess spark...
Built 2 Last TTT
Old 03-11-2011, 03:43 PM   #6
i checked for spark and accidently zapped myself a few times haha
Old 03-11-2011, 03:47 PM   #7
Really?once you have the cel read you will know which direction to go...we can only speculate til then
Built 2 Last TTT
Old 03-11-2011, 04:09 PM   #8
well i was hoping tht i can stumble upon the problem haha
Old 03-11-2011, 04:11 PM   #9
Ha....story of my life...
Built 2 Last TTT
Old 03-11-2011, 04:25 PM   #10
haha well i rebuilt the engine from the block up so hopefully itll run stronggg
Old 03-11-2011, 04:44 PM   #11
Let us know when you get the codes read, only then will we be able to know for sure.
[SIGPIC][/SIGPIC]
Old 03-15-2011, 07:07 AM   #12
Plus 1
PETOM.biz TTT
Old 03-15-2011, 07:18 AM   #13
have you done anything recently to it?
Old 03-17-2011, 09:12 PM   #14
Well I had a guy come to my house and he said fuel pump cuz I was only getting 10 psi of fuel pressure and we checked relays to and we can even keep the car running forever if we keep spraying starting fluid into the intake
Old 03-17-2011, 09:17 PM   #15
Most likely it's the fuel pump same happend to my friends gt recently....
Chris09 is offline   Reply With Quote
Old 03-17-2011, 09:25 PM   #16
04DSGM1's Avatar
Had a similar problem when I was in High School with my first truck. It was bad gas. Not saying this is the problem but just keep it in mind. Trash in the fuel would clog the fuel filter and kill the engine after a few minutes of running.
2004 Dark Shadow Gray Metallic Mach 1
K&N Air Intake
04DSGM1 is offline   Reply With Quote
Old 03-18-2011, 10:41 AM   #17
I'm thinking fuel pump but also it will do that with a bad mass air flow sensor. I don't think it's gonna stay running if the MAF is unplugged or if it's not connected. If it's not fuel pump issue it may be MAF sensor. It will start with a bad MAF but then die.
Alscobra is offline   Reply With Quote
Engine runs hot for v6 Blackedout Pre-2005 V6 Mustang 2 02-20-2011 06:42 PM
Rebuilt AOD stalls engine in reverse and only has 1st gear 91StangGT5.0 1979-1995 Mustang GT 5 11-12-2009 04:02 PM
2002 mustang runs great and then won't start rhonda New Member Introductions & Greetings 1 04-23-2009 08:40 PM
V-12 engine made of paper that actually runs! Scut95 The Bar 7 06-12-2008 06:11 AM
Engine runs, but hesitate/misfire jaynez31 Pre-2005 V6 Mustang 11 01-17-2006 05:30 PM
03:32 PM
