Rattling - Mustang Evolution
Old 03-11-2011, 09:26 PM   #1
Rattling
Whenever I'm driving and come to a stop I hear a small rattle either behind the instrument panel, or behind my radio and cd player... It's coming from in the dash... Any ideas y'all?
Blackedout is offline   Reply With Quote
Old 03-11-2011, 09:56 PM   #2
There is a bee stuck in your dash. Its getting mad every time you stop.
'93 Cobra (Show) '86 Vert (DD)
93CobraGuy is offline   Reply With Quote
Old 03-11-2011, 10:18 PM   #3
Joshy's Avatar
I have the same thing. No clue what it is.
www.petom.biz
Joshy is offline   Reply With Quote
Old 03-11-2011, 10:33 PM   #4
Las0mbra's Avatar
Try the vents, mine rattle a little when I have my speakers up or if I go over bumps. And by vents, I mean the vent panel above the radio.
Old 03-12-2011, 06:00 AM   #5
Re: Rattling
It's easy enough to take apart. I've done it several times but cant imagine what would be vibrating at idle.
Anytime I hear about a V6 noise of any kind, I think about the clutch fork rattle that effects so many of our cars. It drove me mad. It can be described as so, so many different things. Mostly like an engine tapping.
But anyway, thats probably not your issue. Hopefully you can narrow it down by just putting pressure on the spot its coming from and make it stop or sound differently.
Old 03-12-2011, 06:06 AM   #6
More than likely, your dash assemblies might have broken plastic connectors. Whenever I took my radio out, I noticed that all of my little plastic tabs were snapped off. That might be similar to what is wrong with yours. It could also be the venting plastic right below your front window.
Patrick is offline   Reply With Quote
Old 03-12-2011, 07:48 AM   #7
Project Pony's Avatar
My dash vents above the air con controls rattles, I just shoved a quarter in there and no more rattle!
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-12-2011, 08:43 AM   #8
How do I take the radio out?
Old 03-12-2011, 11:21 AM   #9
If your car is anything like a 1998, you'd have to take the center console assembly thing out. There are two screws below the radio, I believe. Then you gotta take the ac vents out using a flat head screw driver. It pulls out after that.
Old 03-12-2011, 11:35 AM   #10
It's a 2000
Old 03-12-2011, 02:14 PM   #11
It should be about the same. Just be careful with the top of the housing. Two clips up there are easy to break. Plus, you'll have to have your shifter back to get the assembly out.
Old 03-13-2011, 03:46 PM   #12
I found the rattling sound my new exhaust systems tip was loose and the sound traveled through the header....
Old 03-14-2011, 04:12 AM   #13
Bad weld?
[SIGPIC][/SIGPIC]
Old 03-14-2011, 04:59 AM   #14
Nadda... You no how break pads have that tin metal outside the part that's usually glued on??? Well that tin part came loose and started wearing away into my rotar.
Old 03-14-2011, 05:00 AM   #15
O wow I posted on the wrong thread... >.< damn... No not a bad weld at all. My exhaust are bolt ons
Old 03-14-2011, 06:45 AM   #16
Ah I see. I had mine all welded that why I ask, I found a spot they missed and had them fix it, as for you brakes how bad did it get your rotor?
[SIGPIC][/SIGPIC]
Old 03-14-2011, 07:10 AM   #17
Re: Rattling
as said, the vents like to rattle
Old 03-14-2011, 04:40 PM   #18
@ project pony it scrapped a little off the rim of the rotor close to the wheel but hardly any damage.... So that's a good thing...
rattling exhaust upton7 1996-2004 Mustang GT 4 04-15-2009 02:13 PM
More Iranian sabre rattling: MarkuzLS1 The Bar 0 11-02-2006 08:18 AM
Rattling in speaker? canman Mustang Audio & Video 7 10-15-2004 12:29 PM
something is rattling in my engine. MusclesFromBrussels Pre-2005 V6 Mustang 1 11-02-2003 11:26 AM
Help: Rattling in doors and body panels DropTop_Stang Mustang Audio & Video 22 08-15-2003 06:17 PM
07:39 AM
