Sad News - Mustang Evolution
Old 03-14-2011, 07:33 AM   #1
Hunter's Avatar
Unhappy Sad News
Last night my oil temp gauge shot up to almost Hot. Check the oil and nothing was on the dipstick. Added the quart and half that I had in the trunk to the motor and baby her all the way home. This morning checked the oil and it was way over filled. Also checked the coolant. It has oil in it. The cap was covered in it. I think it would be the head gasket. Not entirely sure though. It is a sad day.
Hunter is offline   Reply With Quote
Old 03-14-2011, 08:06 AM   #2
Do you have a oil cooler on that vehicle. Not sure if they came with one. If oil is in the coolant and not coolant in the oil. Could be oil cooler leaking through if your lucky.
Alscobra is offline   Reply With Quote
Old 03-14-2011, 09:48 AM   #3
Re: Sad News
OEM the v6 does not have an oil cooler, at least not the 3.8L
Old 03-14-2011, 09:53 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Sad News
police cars and ford explorers are the only one's ive seen with oil coolers... i think the gasket is definatley gone.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-14-2011, 05:55 PM   #5
06mustangmike's Avatar
Re: Sad News
sorry dude,could not even say anything that would help
06mustangmike is offline   Reply With Quote
Old 03-15-2011, 12:13 AM   #6
Hunter's Avatar
Unhappy Re: Sad News
Ya I am thinking it is the gasket too. It's going to be this weekend's project unfortunately.
Old 03-15-2011, 02:58 AM   #7
Well count your blessings that it didn't do any damage. And it will give you a chance to look inside and see what kind of shape it's in. Turn a negative into a positive.
Built 2 Last TTT
Old 03-15-2011, 06:07 AM   #8
USAF_stang's Avatar
Re: Sad News
Built 2 Last TTT
+1, normally when I check one thing it turns into me fixing a lot of other stuff that needed to be tiddied up a bit
USAF_stang is offline   Reply With Quote
Old 03-15-2011, 06:53 AM   #9
Well if you get er done all at once then your all set
PETOM.biz TTT
Old 03-15-2011, 06:57 AM   #10
USAF_stang's Avatar
Re: Sad News
yeah there's always little things but they add up quick....some ppl (like myself) need that one thing that makes you take it all apart and stop being lazy lol.
Not saying you are Hunter...referring to myself lol
Old 03-20-2011, 10:21 AM   #11
Hunter's Avatar
Re: Sad News
The names Eric by the way. Turns out it wasn't my head gasket. Just the oil pressure regulator. Put a new one on and that fixed it.
Old 03-20-2011, 10:26 AM   #12
Re: Sad News
cool,glad it wasn't anything more severe,good luck
Old 03-20-2011, 10:33 AM   #13
Hunter's Avatar
Re: Sad News
Ya me too.
Sad news SrATEX The Bar 10 12-08-2008 06:30 AM
Monkey.... and all others sad news... Brent The Bar 10 09-25-2005 05:18 PM
Sad Sad SAD day Seph The Bar 9 04-06-2004 10:24 AM
sad sad sight Ken The Bar 14 12-22-2003 09:14 AM
today is a sad sad day... Zim The Bar 2 07-24-2003 08:38 AM
02:21 PM
