Springs installed today - Mustang Evolution
Old 03-14-2011, 04:51 PM   #1
Project Pony's Avatar
Rides much better than the cut springs, but shocks are banging around. I heard the the fox shocks are shorter and work good with the new edges that are lowered. Anybody know if this is true? I've got to get them replaced because I don't care for all that banging around while going over bumps
Sent from my iPhone using Mustang
ID:	24475   Click image for larger version
Old 03-14-2011, 05:47 PM   #2
How are the kyb gr-2 struts and shocks? Any good for a lowered stang? The reason I ask is I can get a set for for 180 shipped, and after all the money I have sunk into this thing I don't really want to spend more than that.
[SIGPIC][/SIGPIC]
Old 03-14-2011, 06:16 PM   #3
Just checked AM and may get the tokico hp struts and shocks, 330 shipped, just more than I wanted to dish out for em, if I can't find anything that's decent for cheaper I'll just have to bite the bullet.
[SIGPIC][/SIGPIC]
Old 03-14-2011, 06:23 PM   #4
I'd still like some input on putting fox shocks on my 03....
[SIGPIC][/SIGPIC]
Old 03-14-2011, 06:44 PM   #5
Mean green 91's Avatar
Is say if u can get the kyb and make them fit get them I just got kyb all 6 of them from late model restoration 250.00 and they are great!
Mean green 91 is offline   Reply With Quote
Old 03-14-2011, 06:48 PM   #6
I only need for, but I don't. Know if I can use the fox struts and shocks, I thought I read somewhere that I could and they would work good with he lowering springs, but I can't find it again and want to make sure before buying them.
[SIGPIC][/SIGPIC]
Old 03-14-2011, 06:54 PM   #7
Re: Springs installes today
I've herd the same thing but not sure check out late model restoration I'm sure u can find out.
Old 03-14-2011, 07:57 PM   #8
DarkShadows's Avatar
Don't make things work, use what is supposed to belong on there. Koni is what I use ( granted I got the expensive ones) but they make cheaper ones for the average Joe.
Check these out on tirerack.com (check the pic)
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 03-14-2011, 08:04 PM   #9
I just found a bunch of threads, the fox shocks and struts will work and are great for a lowered sn95, so I'm going to order a set of those
[SIGPIC][/SIGPIC]
Old 03-15-2011, 07:29 AM   #10
Re: Springs installed today
you shouldnt have any banging around~ are you talking about bottoming out the shock? Mine never did that either.
Old 03-15-2011, 07:55 AM   #11
Yes after much testing and cursing, shocks and struts were already worn, and I just mad it worse, ordering some kyb fox body struts and shocks, along with new isos from AM. I just got my ball joints in the other day. So when I get all my stuff in, I'll install all at the same time so I only have to get her aligned once. After all the new rotors and pads are on, I'm going to replace all the bushings in the suspension. I think that will get me to the point were everything should be new. Already put a new alt in, and rad and fan, starter, plugs, belt and battery. Just freshening up everything that I can. My goal is to make her look and feel brand new. Oh changing the diff fluid, and might as well upgrade the Clutch and flywheel and cam etc and that should do it....I think
[SIGPIC][/SIGPIC]
Old 03-15-2011, 07:56 AM   #12
My wife isn't too happy about how much money is going into it, everyday I tell her I just ordered this or that, she shakes her head....
[SIGPIC][/SIGPIC]
Old 03-15-2011, 08:27 AM   #13
isos if urathane etc will raise the car up a good bit FYI
Old 03-15-2011, 08:33 AM   #14
That will work out great, she's just low enough that I can't get out of my upper drive way, she needs to go up just a hair
[SIGPIC][/SIGPIC]
Old 03-15-2011, 12:21 PM   #15
Pictures of the new spring and strut on the front (I had some new ones I took off my other mustang) and old strut and cut spring
ID:	24508   Click image for larger version
[SIGPIC][/SIGPIC]
Old 03-15-2011, 01:49 PM   #16
SaleenFiend's Avatar
Did you clean the K Member?
Old 03-15-2011, 01:55 PM   #17
I cleaned everything I could with brake cleaner and wiped all the dirt off
[SIGPIC][/SIGPIC]
Old 03-15-2011, 03:12 PM   #18
Ok, becuase it looks great and almost new... but I saw the brush against it from the wheels so I knew it couldn't be. I try to clean stuff like that all the time. I hate when ppl leave everything but the body dirty.
Old 03-15-2011, 03:40 PM   #19
I clean every part of my car top to bottom when I get a chance, I need to spend some time and do some spring cleaning on the inside still....
[SIGPIC][/SIGPIC]
Old 03-15-2011, 03:41 PM   #20
With the pollen I've been washing and waxing it everyday, I've got a lot of time on my hands and I cant stand that crap on my car
[SIGPIC][/SIGPIC]
Old 03-18-2011, 07:05 AM   #21
Just a FYI: Mustang 5.0 Magazine online today has an article in regards to Edlebrocks new shock/struts exclusively for the SN95's. In the story it reiterates your comment in regards to the Fox's length of shocks.
Thats the same path I have followed after hearing the same thing. I got the KYB shocks/struts, FRPP "B" springs, but also got the MM CC Plates and X2- bumpsteer to insure alignment. I'm lucky as to have a performance race shop within driving distance to help setting it up. Its the fundage for install temporarily holding me up right now.
Good luck with everything.
Edelbrock Shocks - 5.0 Mustang & Super Fords Magazine
Old 03-18-2011, 11:05 AM   #22
I got my fox struts and shocks in today and holy ****! With the new springs she drives like a dream! Very smooth, quiet, and she corners like a bat out of hell.
[SIGPIC][/SIGPIC]
Old 03-18-2011, 11:08 AM   #23
nice get pics of the stance
Old 03-18-2011, 11:17 AM   #24
She sits the same as with the other struts, and she's dirty, getting ready to wash her in a bit
[SIGPIC][/SIGPIC]
Old 03-18-2011, 11:22 AM   #25
Shot of the back shock
[SIGPIC][/SIGPIC]
Old 03-18-2011, 11:28 AM   #26
nice
Old 03-18-2011, 11:35 AM   #27
I put her through her paces. Speed bumps, hard stops, sharp turns, sweeping turns, launches, high speed, and I am very pleased. The cut spring setup can't hold a candle to it now. And the fox struts are perfect for the 1.5" drop.
[SIGPIC][/SIGPIC]
Old 03-19-2011, 10:09 AM   #28
Good Deal.
Which springs are those again??
KYB Gr-2 also?. Congrats!
Old 03-19-2011, 12:19 PM   #29
Dropzone cheapies, just over a hundred bucks for em. I just used the motorcraft foxs shocks and struts, coil overs are going on this summer some time so I didn't want to waste a bunch of money, but I still need it to be drivable as I make trips to Myrtle beach every week or so.
[SIGPIC][/SIGPIC]
Old 03-25-2011, 06:23 PM   #30
good cause my kyb are great and they r a much tighter ride.
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Springs... 232stang01 Pre-2005 V6 Mustang 24 01-07-2005 03:39 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
Got my springs! Tbird232ci Pre-2005 V6 Mustang 7 05-08-2004 12:34 PM
Well... springs should be in soon. Brent Pre-2005 V6 Mustang 24 10-13-2003 06:21 PM
12:01 AM
