Raising the rev limiter with a tune - Mustang Evolution
Old 03-17-2011, 06:12 PM   #1
What is raising the rev limiter on a tuner and is this safe for the car?
Blackedout is offline   Reply With Quote
Old 03-17-2011, 06:24 PM   #2
Why would you want to?
11SHELBYGT500 is offline   Reply With Quote
Old 03-17-2011, 06:25 PM   #3
I don't know I'm really not saying I want it I jus wanna know what it is...
Old 03-17-2011, 06:38 PM   #4
Raising your limiter would hurt your engine, but I think you might be talking about your top speed governor.
Old 03-17-2011, 06:40 PM   #5
Depends on how much you raise it...a couple hundred rpm isn't too bad,1000 will cause valve float and possible failure
PETOM.biz TTT
Old 03-17-2011, 06:43 PM   #6
Top speed governor
Old 03-17-2011, 06:44 PM   #7
PETOM.biz TTT
Agreed ^^^ but I don't see a benefit from raising your limiter 300 over your redline.
Old 03-17-2011, 06:46 PM   #8
I don't see any benefit at all...torque and hp peak are well below the rev limit...ford got this one right on. Unless you have improved valvetrain there really isn't any point or use
PETOM.biz TTT
Old 03-17-2011, 06:47 PM   #9
PETOM.biz TTT
Agreed^^^
Old 03-18-2011, 09:33 AM   #10
Lone Star's Avatar
Re: Raising the rev limiter with a tune
There is absolutely no need to raise the rev limiter on your car, it will not benefit you in any way! hp/torque numbers hit the highest peak before red line. Your car has a factory set top speed based on your stock tire speed rating, the tuner will allow you to raise the speed limiter to levels you will never see. that said I recommend if you raise the limit to get higher speed rated tires(performance tires) or take the risk of catastrophic tire failure and at those speeds possible death
Northern Virginia Mustang Club
Silver Mustang Registry #1045
2010 Brilliant Silver 4.0 V6 Traded and will be missed
2011 Performance White Premium GT 5.0 6MT, 19" Machined Wheels, 3.73 gears, GT500 Axle-Backs, Eibach Pro Springs, Dynojet #'s 387rwhp/380 tq.
Lone Star is offline   Reply With Quote
Old 03-18-2011, 09:43 AM   #11
Wow...catastrophic eh
PETOM.biz TTT
Old 03-18-2011, 09:44 AM   #12
the reason you should really be careful is the car makes its peak power at X rpm, no need to go much if any above that ever, your just losing power. The next thing is the motor will only be able to take X rpm before major issues take place, you want to stay away from that, Thats why the rev limiter is there to begin with.
Old 03-18-2011, 12:09 PM   #13
Titus Wadicus
svtlx's Avatar
+1
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-18-2011, 12:13 PM   #14
stampde's Avatar
NICE ......... Speed rating is sustained speed ,if you go 150 on a set of 120 rated tires it's not really going to be that bad , unless your doing 150 for a long period of time ,that will cause the tires to heat up ,blah blah ,blah
2011 GT Auto
Old 03-18-2011, 12:27 PM   #15
speed limiter is not always the same as rev limiter
Old 03-18-2011, 12:40 PM   #16
Project Pony's Avatar
My buddy's rice limiter is broken in his Kia
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-18-2011, 12:44 PM   #17
Ha....use extra soya sauce to keep er from exploding
PETOM.biz TTT
Old 03-18-2011, 12:46 PM   #18
Your a life saver,I got to let him know before his motor goes kung pow!
[SIGPIC][/SIGPIC]
Old 03-18-2011, 03:58 PM   #19
Hehehe
PETOM.biz TTT
Old 03-18-2011, 09:17 PM   #20
As said, the rev limiter is different from the speed limiter.
The rev limiter should just stay on...the peak power is well before redline and there's really no point in removing it, unless you wanted to see how many times you could rev your car consecutively before hearing "cool" (not) noises.
The speed limiter is set at 115 for 99-04 v6's. The reason being limited at that speed is due to the OEM tires on the cars. The 225/55/16 Goodyear Eagles and smaller 15" tires on 99/00 v6's were 115 mph tires.
You could remove the speed limiter if you wanted to go faster than 115, but I personally think there would rarely be a time when you need to go any faster, and let's be honest, the v6 isn't necessarily built for top end...you'll most likely run out of good road before getting there, lol.
Now if you happened to own a 99-00 GT with the base 16" wheels and you're limited to 115, you might want to remove that limiter to reach that higher speed/
2011 Rev Limiter a_Gorman 2011-2014 Mustang GT 28 02-24-2011 04:39 PM
How can I disable my rev limiter. upton7 1996-2004 Mustang GT 33 04-30-2010 01:49 AM
Dual-Stage Rev Limiter blue-saleen Pre-2005 V6 Mustang 5 12-10-2009 08:00 PM
nitrous and rev limiter 02whitestang Pre-2005 V6 Mustang 2 02-12-2004 09:04 PM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 12:25 PM
04:26 PM
