when i turn my car squeaks - Mustang Evolution
Old 03-17-2011, 08:39 PM   #1
austinknoll's Avatar
It's sooooooooooo annoying.. Whenever I turn my car makes this little squeaky noise it's so annoying. It makes my car sound so unmanly. Any help would be appreciated because I want to get this fixed asap
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 03-17-2011, 08:41 PM   #2
Jamesgt08's Avatar
Could be your power steering pump.
Jamesgt08 is offline   Reply With Quote
Old 03-17-2011, 09:31 PM   #3
Project Pony's Avatar
Where is the squeak coming from? And is it a squeak or a whine? Could be ball joints, power steering, springs, brakes, we need more info
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-17-2011, 09:32 PM   #4
Otlaw80's Avatar
Re: when i turn my car squeaks
Ball joints will squeak, power steering is a possibility but that usually "groans". Control arm bushings will do it. Stupid question but are your tires inflated properly?
Old 03-17-2011, 09:32 PM   #5
If it's only when turn brakes is out, could be ball joints or power steering, post a video
[SIGPIC][/SIGPIC]
Old 03-17-2011, 09:34 PM   #6
Otlaw80's Avatar
brakes are a slim possibility even if its just when you turn. The caliper will "flex" with the sideways pressure while turning and could cause a crack in the pad or the indicator to rub the rotor slightly.
Old 03-17-2011, 09:37 PM   #7
Pin point where it is coming from. Have someone check while you turn the wheel. Does it do it in both directions?
[SIGPIC][/SIGPIC]
Old 03-17-2011, 09:45 PM   #8
04DSGM1's Avatar
It could be moisture on the belt and it is slipping on your pullies. That happened with my Ranger. After about a minute the squeaks would stop. After it would warm up a bit and the moisture was gone.
2004 Dark Shadow Gray Metallic Mach 1
K&N Air Intake
04DSGM1 is offline   Reply With Quote
Old 03-17-2011, 09:54 PM   #9
It's something suspension related.
93CobraGuy is offline   Reply With Quote
Old 03-17-2011, 09:55 PM   #10
He needs to narrow down where it is coming from.....
[SIGPIC][/SIGPIC]
Old 03-17-2011, 10:00 PM   #11
You could have someone drive it in a parking lot for you and you can stand outside of the car and listen.
Also have someone sit in the car and turn the wheel while sitting still to see if you can hear it as well.
Might help you at least figure out what side its coming from. Squeaks are tricky little things.....
Old 03-17-2011, 10:01 PM   #12
Agreed, do that and you will be much better armed to kill that squeak
[SIGPIC][/SIGPIC]
Old 03-18-2011, 09:56 AM   #13
I know for a fact its prolly ur ball joint I had the same problem. Does it squeak when u hit bumps or uneven paves?
Blackedout is offline   Reply With Quote
Old 03-18-2011, 10:23 AM   #14
stampde's Avatar
ok , I'll be the wise guy today : so don't turn it
2011 GT Auto
Old 03-18-2011, 10:37 AM   #15
is it at a full lock of the steering wheel or just normal turning?
Old 03-18-2011, 03:51 PM   #16
SaleenFiend's Avatar
FIX: Don't turn.
edit: Someone beat me to it!!
Old 03-19-2011, 03:46 PM   #17
Joshy's Avatar
Hahah nice
www.petom.biz
Joshy is offline   Reply With Quote
Old 03-20-2011, 04:37 PM   #18
When it's locked it won't squeal only when I'm tirnig the steering wheel will it squeak
65 Mustang coupe
Old 03-20-2011, 05:01 PM   #19
Ball joints or tie rods, ball joints are easy and doesn't cost a whole lot.
[SIGPIC][/SIGPIC]
Old 03-20-2011, 05:01 PM   #20
Same for tie rods, just get it aligned afterwards
[SIGPIC][/SIGPIC]
my car dont turn on juced302 1979-1995 Mustang GT 6 01-16-2010 10:22 PM
crunches and squeaks stang00 Pre-2005 V6 Mustang 9 09-13-2006 10:52 AM
My turn: Rellik The Bar 16 08-09-2003 10:39 AM
Steering squeaks NorwegianMustang Pre-2005 V6 Mustang 1 07-31-2003 11:12 PM
04:52 PM
