want to get a GT hood - Mustang Evolution
Old 03-18-2011, 12:14 AM   #1
tvsr's Avatar
Region: Nevada
I have a 99' v6 with the regular hood but I like the GT hood where the hood's cowl is open. I want to find one and put it on my v6 but will it fit? is the GT hood the same as the v6 or does it have a ram intake or something on the cowl?
20" rims, Low profile Falken tires, dropped, AM Cold Air Intake, MSD Super Conductor Wires, Flowmaster muffler, GatorBack Belt, Vented cross cut Rotors, Blacked out lights, BEM Reverse Glow Gauges...
tvsr is offline   Reply With Quote
Old 03-18-2011, 12:16 AM   #2
Jamesgt08's Avatar
Yes it will fit ur v6 theres no ram intake. You can just buy the scoop and drill the holes in ur v6 hood and bolt the scoop down. It will look just like the gt hood.
Jamesgt08 is offline   Reply With Quote
Old 03-18-2011, 12:18 AM   #3
Ummmm not quite. The scoop is seamless. You would need body filler and paint. Just find the hood you like...it's a bolt on
PETOM.biz TTT
Old 03-18-2011, 12:27 AM   #4
tvsr's Avatar
Region: Nevada
Re: want to get a GT hood
How would the scoop fit in though? Over the hood or would I have to cut a hole in the hood?
Old 03-18-2011, 12:28 AM   #5
I would just go with a replacement GT hood if I were you, it would look a lot cleaner. You might even be able to find one the same color as your car at a parts yard if you are lucky!
93CobraGuy is offline   Reply With Quote
Old 03-18-2011, 12:48 AM   #6
bbunt302's Avatar
PETOM.biz TTT
Hate to disagree, but the scoops are not seamless. They just bolt on. You just have to make sure the holes you drill are lined up correctly. Ask SpectorV. He did this on his black V6 and it looked just like a GT. The scoop alone will be a lot cheaper than the entire hood, assuming you can still find them.
Scary stuff.
Old 03-18-2011, 01:30 AM   #7
Well if that's all there is to em who sells em...
PETOM.biz TTT
Old 03-18-2011, 01:32 AM   #8
Jamesgt08's Avatar
My car i bought a v6 hood and i put the scoop on myself it has bolts u gotta drill holes and bolt it down.
Old 03-18-2011, 02:23 AM   #9
110 bucks at AM. And no holes to drill,2 sided tape. Thanks bbunt
PETOM.biz TTT
Old 03-18-2011, 06:02 AM   #10
Project Pony's Avatar
I prefer the more rounded scoops
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-18-2011, 08:12 AM   #11
you just need the hood scoop, thats all the GT has is a scoop thats bolted on top of the stock V6 hood (up till 04, the 04 has a different hood for the V6)
For 99-00 it also can be installed but it is a bit harder than 01-03. The reason 01-03 are easier is thats why the GT started having the hood scoop and ford modified the underside of the hood a bit for installation of a scoop. The V6 has the same hood as the GT minus the added on scoop.
Back in the day the scoop was 100 bucks painted~ now not so sure. If you can find one at a junk yard you can unbolt it from the bottom and pop it off rather easy.
I have installed on an 00 model and an 01 model so I can do either, but the 99-00 models the part you have to do is measure all angles so you know where to center it on the hood and make a template and drill the holes, not hard just takes a little time. Feel free to PM me and we can go over the logistics of it.
Old 03-18-2011, 09:47 AM   #12
Old 03-18-2011, 09:50 AM   #13
PETOM.biz TTT
Right here spec..unpainted
PETOM.biz TTT
Old 03-18-2011, 01:04 PM   #14
Topless04GT's Avatar
Spec is spot on... i love how this topic comes up on the day that I hit the worlds fattest f'n bird and it destroooooyed my scoop... Im not rocking the v6 look lol... I have shaved trunk and no scoop haha
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 03-18-2011, 02:24 PM   #15
the stick on is not the OEM looking one I bet, I am not sure I would trust that.
for 99-00 you just have to measure exactly where the scoop is and transfer those measurements to your hood. Then take a cardboard piece thats flat and sit the scoop on it and punch the holes where the bolts are. Tape the template down exactly where the scoop needs to go (outline the scoop and cut i tout when its pushed down on the cardboard) then after its taped down drill the holes, drill a couple and test fit.
Go around that way. For the very front one GET IT RIGHT take your time, for the angled ones... they are tricky you may have to drill the hole bigger as if the bolts dont line up right they can bind and keep the scoop from sitting flush.
One last thing if its 01-03 if you take the hood mat out from under the hood (do this for any year first dont drill through it lol) you can see two silver dollar holes towards the back middle, thats where the two back bolts go so you can drill those out and then just sit the template on the hood stick some pins in the hole to line it up, tape it down and drill put a bit of lock tite on the bolts and snug em down.
Old 03-18-2011, 06:17 PM   #16
SVTCOBRA's Avatar
If you would like a OEM scoop Id go with Tousley Ford. They have good prices and have an awesome customer service.
Tousley Ford Parts Depot
Like bburnt302 said they just bolt in if the drilled hopes are lined up correctly. Ive done a few at work and they are pretty simple.
A Super Torque Ford!
"The problem with socialism is that eventually you run out of other people's money." (Margaret Thatcher)
SVTCOBRA is offline   Reply With Quote
Old 03-20-2011, 10:28 PM   #17
tvsr's Avatar
Region: Nevada
Thanks spectorv im going to look around the junk yard and ebay and see if I can find the scoop. Oh its for a 1999, I know AM has a scoop but I like the rounded look. When I find a scoop I'll post it up. Thanks for the info, also does the GT scoop vented into the motor or is the scoop closed off like the v6?
Old 03-21-2011, 07:52 AM   #18
I'd don't believe it is functional
[SIGPIC][/SIGPIC]
Old 03-21-2011, 08:54 AM   #19
A.K.A. Baby-D!
its not functional.. just bolt on.
and as mentioned the 04 V6 hood is different and it sucks. to get the GT look i would have to get a whole new hood. but i kinda like my reverse scoop.
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 03-21-2011, 09:51 AM   #20
Mine wouldn't look good with a scoop
[SIGPIC][/SIGPIC]
Old 03-21-2011, 12:37 PM   #21
the scoop is just for looks and should have a grill at the front of it to close it off (honey comb grill)
WTT: 00 R hood (opened louvers) for 03/04 Termi hood jimmy_beaner Mustang Parts for Sale and Wanted 14 07-05-2009 08:15 AM
FEELER: WTT 04 cobra hood for cowl hood SimplyOrange Mustang Parts for Sale and Wanted 18 08-16-2008 06:13 PM
'02 Black Mustang Hood w/ GT Hood Scoop mattstang Mustang Parts for Sale and Wanted 8 08-22-2006 10:11 AM
Hood Scoop + 04 base model hood Exit_In_Red Mustang Audio & Video 7 10-22-2004 07:10 PM
WTT: Redfire '03 V6/Cobra hood for GT hood w/ scoop tire Mustang Parts for Sale and Wanted 0 02-21-2004 11:07 AM
11:39 AM
