Cold air intake with breather - Mustang Evolution
Old 03-23-2011, 06:58 PM   #1
If I bypass the hose from the oil crank that connects to the cai and replace the oil crank with a breather will that successfully add 1 or 2 more hp?
Blackedout is offline   Reply With Quote
Old 03-23-2011, 10:23 PM   #2
Joshy's Avatar
Lol. How much do u plan to gain or did u gain from the CAI?
www.petom.biz
Joshy is offline   Reply With Quote
Old 03-23-2011, 10:32 PM   #3
Re: Cold air intake with breather
I really wouldn't be worried about 1 or 2 HP. You could take the trunk carpet out and gain more performance than 1 or 2 HP.
93CobraGuy is offline   Reply With Quote
Old 03-23-2011, 11:08 PM   #4
Ha...nope
PETOM.biz TTT
Old 03-24-2011, 02:35 AM   #5
Project Pony's Avatar
Take out your spare too, lighten the load
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-24-2011, 02:46 AM   #6
If done properly, it will reduce the amount of condensation and gunk build up in the upper intake manifold. I do not believe it as easy as how you described it though.
Go to SuperSixMotorsports.com and read the "pcv delete/bypass" instructions before you attempt it.
Good luck with it.
Old 03-24-2011, 11:19 PM   #7
I went ahead and done it it seems to work jus fine
Old 03-25-2011, 07:16 AM   #8
it wont do anything other than keep potential oil out of the intake. There are huge discussions on metered vs non metered air~ if there is no oil in the intake, leave the connection.
Old 03-25-2011, 07:37 AM   #9
Could the breather be harmful?
Old 03-25-2011, 07:46 AM   #10
Bc I seen a guy do this on u tube
Old 03-26-2011, 10:36 AM   #11
Did you read the write up on SSM?
Old 03-26-2011, 10:52 AM   #12
Not yet I will
Old 03-26-2011, 12:50 PM   #13
Good luck with it.
Looking it up right now
Old 03-26-2011, 07:46 PM   #14
Ok I read it
Old 03-27-2011, 06:14 AM   #15
Originally Posted by Blackedout View Post
Ok I read it
Is that how you did it too? I remember reading it and not fully comprehending everything 100%. I was going to call them before doing it but now I seem to have everything under control with Seafoam treatments and a catchcan in the works.
Old 03-27-2011, 07:03 AM   #16
Eliminating the entire set up isn't a good idea IMO. Fords engineers had good reason to put it there. If vapourized oil was a bad idea I am sure they woulda done something about it. Personally I think unless your boosted the catch can is a waste of money. There is so little oil being sucked into the intake and it's far enough upstream that it re-condenses long before it hits the combustion chamber. Put in a catch can if you really are concerned however it's irrelevant....unless your boosted. Under boost much more oil seems to vapourize however still a mute point because it simply isn't a problem. It not as if it's going to foul plugs or ruin sensors.
PETOM.biz TTT
Old 03-27-2011, 07:05 AM   #17
This is good advice. If it isn't causing a problem don't **** with it. If it ain't broke don't fix it. And as far as un-metered air is concerned there is so little being sucked in from that minute tube that it's irrelevant.
PETOM.biz TTT
cold air intake
2.3 Cold Air Intake MC770 2.3 Mustang 12 12-01-2010 09:35 PM
05 GT cold air intake? 0351mike 2005-2010 Mustang GT 14 09-12-2010 08:49 PM
Looking for a cold air intake maxwelmurder Pre-2005 V6 Mustang 10 08-31-2008 08:41 AM
cold air intake fastang11 Pre-2005 V6 Mustang 11 01-08-2006 10:35 PM
Mass Air Flow and Cold Air Intake Mike's-stang Pre-2005 V6 Mustang 1 08-20-2004 09:24 AM
09:59 AM
