Overheating, no cirrculation, No hot AC - Mustang Evolution
Old 03-28-2011, 05:34 PM   #1
tvsr's Avatar
Region: Nevada
Exclamation Overheating, no cirrculation, No hot AC
Hey guys I'm having a REALLY big problem. My 1999 Ford Mustang v6 3.8L is overheating strangely. It's been overheating when I drive less than a mile. I added antifreeze, changed the thermostat, put a stop leak treatment in the radiator, there are no leaks either, also there is no hot air coming out of the AC, it can't be the water pump either because it was changed about 4 months ago. I've been looking around the web and heard it may be the heater core. Any suggestions or other compontents that it may be? Thanks!
20" rims, Low profile Falken tires, dropped, AM Cold Air Intake, MSD Super Conductor Wires, Flowmaster muffler, GatorBack Belt, Vented cross cut Rotors, Blacked out lights, BEM Reverse Glow Gauges...
tvsr is offline   Reply With Quote
Old 03-28-2011, 05:40 PM   #2
Re: Overheating, no cirrculation, No hot AC
That stop leak crap is pretty much useless and is known to also clog up a cooling system. It' could be that your heater core is clogged. Are you experiencing any smoke from the exhaust? Check your oil to see it it has bubbles from coolant in it as well. Could be a blown headgasket.
93CobraGuy is offline   Reply With Quote
Old 03-28-2011, 05:46 PM   #3
tvsr's Avatar
Region: Nevada
no there's no smoke coming out from the exhaust, the oil is fine as well. Could air in the system cause this?
Old 03-28-2011, 05:51 PM   #4
Yep. Find the high point bleed. Fill it from there. Squeeze the lower hose until there is no more air in the system.
Sno. push the goddamn button!!!
Alscobra is offline   Reply With Quote
Old 03-28-2011, 05:55 PM   #5
tvsr's Avatar
Region: Nevada
Sorry but whats the high point bleed
Old 03-28-2011, 05:59 PM   #6
There should be a cap or plug or something at the highest point of your cooling system.
Old 03-28-2011, 06:03 PM   #7
tvsr's Avatar
Region: Nevada
oh ok thanks, one more thing though, when I flush it with water does it go inside the motor or do i disconnect the upper hose?
car overheating AGAIN!!!! Senorjizzy Pre-2005 V6 Mustang 4 09-01-2009 08:04 AM
Overheating 06 probchld1953 2005-2010 Mustang GT 7 06-10-2008 07:25 AM
Overheating problem? Fast93Coupe 1979-1995 Mustang GT 1 07-01-2006 12:29 PM
Overheating problem NorwegianMustang Pre-2005 V6 Mustang 7 04-27-2005 02:52 PM
yet, another overheating story. juanmiguel Pre-2005 V6 Mustang 15 01-04-2005 12:10 PM
09:41 AM
