Cooling Fan Wiring??? - Mustang Evolution
Old 04-05-2011, 11:54 AM   #1
Bought a 96 with aftermarket cooling fan, has been wired to the battery and uses a remote temp sensor. Fan will run when the car is shut down untill water temp is down, sometimes takes quite a while and can't be good for the battery.
On a standard configuration will the fan run when the car is shut down?
Also water temp gage does not work, replaced temp sensor, no fix, gage is dead. May explain the aftermarket fan???
dino.999 is offline   Reply With Quote
Cooling Fan Temp Sensor Placement??? dino.999 Pre-2005 V6 Mustang 0 03-11-2011 08:05 AM
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
Problem with the cooling fan coming on... Kiljosh Pre-2005 V6 Mustang 5 08-26-2008 04:52 PM
cooling fan upgrade madmax680 1979-1995 Mustang GT 8 06-09-2006 12:34 PM
cooling 9899musl 1996-2004 Mustang GT 0 03-14-2006 05:24 PM
05:51 AM
