Adjusting idle - Mustang Evolution
Old 04-05-2011, 02:47 PM   #1
Adjusting idle
Alright guys I'm wanting to adjust my idle from 750 to 1k.... Is this possible and how do I do this? If not, then let me know Bc I'm still learning
Cody156 is offline   Reply With Quote
Old 04-05-2011, 03:41 PM   #2
Joshy's Avatar
Why adjust your idle?
www.petom.biz
Joshy is offline   Reply With Quote
Old 04-05-2011, 03:43 PM   #3
Re: Adjusting idle
What year car?
If its a newer car and not carbed, odds are you will need a hand held tuner or a chip to do it.
And like was mentioned, why do you want to idle at 1k?
Old 04-05-2011, 05:27 PM   #4
2000 v6
And Bc the way my exhaust is set up you dont really hear it at idle(750) but it has a nice rumble sitting after startup at 1k
Old 04-05-2011, 05:33 PM   #5
Joshy's Avatar
2000 v6
Wouldn't that be like throwing away gas and bad for your motor? Just guessing
www.petom.biz
Old 04-05-2011, 05:37 PM   #6
Probably Change your mpg a little but not noticeably. Maybe a mile or 2. And if you think about it you drive your stang in a range of 750-4000 everyday, so letting it sit 250+ over normal idle wouldn't be hurting it.
Old 04-05-2011, 05:37 PM   #7
I guess to answer my own question I could find a smaller idle pulley and different belt size
Old 04-05-2011, 05:51 PM   #8
Idle is controlled by the computer. It is moderated by the idle air contol valve. An idler pulley is just a pulley used in routing your belt. It has nothing to do with your idle.
You could jack with your iac valve to trick the computer, but then you are setting your car up outside the normal parameters.
Old 04-05-2011, 08:24 PM   #9
Titus Wadicus
svtlx's Avatar
Re: Adjusting idle
use the idler pulley to adjust the idle..duh..... why didnt i think of that?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-06-2011, 01:04 AM   #10
Re: Adjusting idle
Yes you can adjust your idle. The idle screw is located under the throttle cable on the throttle body. Follow the cable until it ends on a curved bracket. It should be idling at 900.
Typically, like mentioned the computer controls it unless you have installed under drive pulleys. If that's the case, turn the screw with flat head screwdriver clockwise until your at 900 rpms.
Be careful though, if there is something else retarding the idle take care of it (like maintenance items)
Old 04-06-2011, 07:29 AM   #11
Re: Adjusting idle
I would personally not mess with it, it may sound a little better but its not worth all the hassle.
Old 04-06-2011, 08:00 AM   #12
Alright well I'm lookin to get underdrives, will that change my idle at all
Old 04-06-2011, 08:24 AM   #13
Re: Adjusting idle
Um, the computer is still going to command a specific idle. It is going to tell the IAC valve to either open or close the throttle body in order to maintain the idle at it's commanded value. The COMPUTER controls the idle. The Computer has a commanded idle RPM. The COMPUTER will not change it's commanded idle RPM until you get a tuner and you change the commanded RPM and then reflash the COMPUTER.
Do you see a pattern here?
Old 04-06-2011, 08:27 AM   #14
Haha yeah the pattern is very FAINT but I think I get it.
Old 04-06-2011, 08:30 AM   #15
Re: Adjusting idle
Yeah, sometimes I am a little too vague in my replies...it's something I'm working on.
Old 04-06-2011, 08:38 AM   #16
So I guess the typical answer is to get a tuner right?
Old 04-06-2011, 09:45 AM   #17
Re: Adjusting idle
For ODBII cars, yes.
Old 04-06-2011, 10:04 AM   #18
ODBII?
Old 04-06-2011, 10:07 AM   #19
Re: Adjusting idle
ODBII?
The generation of computer. Mustangs went ODBII in 1996.
Old 04-06-2011, 10:29 AM   #20
Re: Adjusting idle
get a tuner if you really want it changed and have the tune written for it up the idle. This means you will probably need a custom tune written (best way to go anyway). You can pick your octane so you wont have to run premium if you dont want to as well.
Old 04-06-2011, 10:55 AM   #21
Alright thanks
Old 04-07-2011, 12:42 AM   #22
K by adjusting your idle up your going to go thru brakes a bit quicker because the car is going to push a bit harder when your not on the gas. And as already mentioned a 96 and newer will need a tuner to up the idle because even if you crank the screw to force it to idle higher the adaptive learning will eventually bring it back down to stock setting. Ultimately a tuner is your only option
Adjusting the Clutch pringle9666 Pre-2005 V6 Mustang 10 06-14-2010 11:18 AM
Adjusting Idle and Timing sonicpony03 Pre-2005 V6 Mustang 1 07-23-2008 08:14 PM
adjusting the carb on an 82 GL? I_luv_HP&trq Pre-2005 V6 Mustang 8 09-28-2005 12:14 PM
adjusting the clutch? Murph00 Pre-2005 V6 Mustang 4 01-27-2005 05:02 PM
?adjusting the cam position sensor? Horse Pre-2005 V6 Mustang 24 10-18-2004 06:01 PM
05:57 AM
