The next upgrade... - Mustang Evolution
Old 04-05-2011, 08:32 PM   #1
The next upgrade...
My next upgrade is going to be 3.73s gears and positive traction... Any help???
Blackedout is offline   Reply With Quote
Old 04-05-2011, 08:42 PM   #2
Joshy's Avatar
What is positive traction?
www.petom.biz
Joshy is offline   Reply With Quote
Old 04-05-2011, 09:01 PM   #3
Re: The next upgrade...
Here in the Ford world we call that Trac Lok. It's when both drive wheels are locked together with clutches in the differential. It makes both tires grab traction instead of just one, which is called an open differential or one wheel peel.
93CobraGuy is offline   Reply With Quote
Old 04-05-2011, 09:02 PM   #4
Joshy's Avatar
Ok. I was gonna say... I know what TLock is. Thanks for clearing it up
www.petom.biz
Old 04-06-2011, 08:02 AM   #5
Hunter's Avatar
Your best bet is to fine a 9inch chunk that is 3.73s that you can just put right in. I know I have a few sitting around. I'm going to be doing that this summer. Putting a whole chunk in is easier than putting all those gears and clutchs in seperate and possibly messing something up.
_____________
Landis
Hunter is offline   Reply With Quote
Old 04-06-2011, 09:16 AM   #6
wereKEV's Avatar
That's a good and easy idea.
wereKEV is offline   Reply With Quote
Old 04-06-2011, 07:45 PM   #7
That is an easier alternative...pick up an 8.8" rear from a GT or other solid rear axle car and bolt it up. Pick up some quad shocks, taller gears and a tlok re-build kit and you're set. Then you'd be set for FI or major power increases in the future.
A 7.5" tlok and gears would suffice for a stock/near stock v6. Expect to pay 150-180 each for the gears and tlok and anywhere from 300-500+ for install depending on the shop. Keep in mind installing gears is no simple matter and even a shop can make mistakes which will result in gear whine. It is crucial to get a written agreement from the shop saying that any gear whine is caused by improper install and will be adjusted...that usually weeds out the crap shops that wouldn't install the gears right in the first place.
Just did the best upgrade ever Project Pony Pre-2005 V6 Mustang 10 03-11-2011 09:29 AM
help with new upgrade upton7 1996-2004 Mustang GT 0 03-28-2009 07:19 PM
Next Upgrade?? 2kslvrgt 1996-2004 Mustang GT 6 02-07-2009 02:56 PM
Upgrade Stang02021 Pre-2005 V6 Mustang 34 02-05-2009 09:54 AM
3G Upgrade bluemustang 1979-1995 Mustang GT 11 06-06-2007 09:54 PM
10:20 PM
