Changing Front Brakes - Mustang Evolution
Old 04-07-2011, 09:17 PM   #1
I'm going to tackle new brake pads tomorrow morning for the front. I've changed brake pads in the past and it was all pretty straight forward. Anything surprises I should expect to run into? Is it just two bolts per caliper or is there more?
Thanks guys.
Vince
SuperKirby is offline   Reply With Quote
Old 04-07-2011, 10:48 PM   #2
Thanks guys.
Vince
If it's just on the front then yea it'll be super easy. Two bolts, remove caliper, remove pads, compress cylinder, insert new pads, replace caliper onto rotor, redo bolts. BAM your done in 10-15 minutes Max
Cody156 is offline   Reply With Quote
Old 04-07-2011, 10:51 PM   #3
gonzo56's Avatar
Region: New Mexico
Re: Changing Front Brakes
This is a bit of over kill but good!
How-To Install a Big Brake Kit & Bleed Your Brakes - Motorz TV
gonzo56 is offline   Reply With Quote
Old 04-08-2011, 08:53 AM   #4
SaleenFiend's Avatar
You may need to resurface the rotors.
Old 04-08-2011, 09:47 AM   #5
its easy other than breaking those damn bolts loose, dont take out the wrong bolts (there are 4, two of them done need to come out the two you want hold the caliper onto the spindle. Make sure you use correct tq amts on re installation.
Old 04-08-2011, 10:35 AM   #6
bbunt302's Avatar
As long as you're just doing the front, it's pretty straightforward. To do the rears, you have to have a special tool to compress the rear caliper pistons.
Scary stuff.
Old 04-08-2011, 04:00 PM   #7
Just did the fronts. And it would have been easy, if the people before had changed the pads once in awhile. Instead everything was kind of shot. All the pads were worn down completely so it was metal on metal. And one of the boots around the piston and split so it didn't have any fluid around it and siezed up. So yeah, I got to buy a new caliper too. Other than that it was fun. Or something. Next weekend it will be the fuel filler neck and grommet. Yay!!!
Old 04-08-2011, 04:35 PM   #8
Nice... I assume you got new rotors or resurfaced the ones you had?
Did you bleed the brake system?
Old 04-09-2011, 04:55 PM   #9
Yep it all works good now. I took it out for a little romp session. I figure I had to, you know, to make sure I fixed it right. And you can't stop fast unless you first go fast, right?
Tit problem on front brakes. I'm stuck ajpturbo 1996-2004 Mustang GT 14 09-22-2010 08:26 PM
Changing front bushings: how to? DarkShadows 1996-2004 Mustang GT 8 09-11-2009 08:23 AM
Changing front blinker bulb? jmy2469 2005-2010 Mustang GT 8 06-04-2008 11:00 AM
BRAKES front & rear chris7869 Pre-2005 V6 Mustang 1 09-08-2007 07:16 PM
front brakes 96bluegt 1996-2004 Mustang GT 2 05-21-2007 08:20 PM
12:49 AM
