Rear Trailing Arm - Mustang Evolution
Old 04-09-2011, 04:44 PM   #1
Rear Trailing Arm
2000 v6 mustang. Doing a gear swap. I got every bolt out of the rearend except the right trailing arm where it mounts to the rearend. The bolt is stuck. Its spinning with the impact, and im prying on it and its still not coming out. IDFK what to do!!! I dont want to heat it up because i dont want to replace the bushing and whole trailing arm bc i have dual exhaust thats in the way of the trailing arm bolt so itd be more trouble than its worth. Any help would be GREATLY appreciated.
pringle9666 is offline   Reply With Quote
Old 04-10-2011, 09:01 PM   #2
Re: Rear Trailing Arm
BUMP!!!
Old 04-11-2011, 02:43 AM   #3
The bolt is seized inside of the metal sleeve in the bushing. This is also common on Fox cars as well. Your'e going to need a cutoff wheel and an new bushing. A sawzall won't work, been there, done that, lol.
93CobraGuy is offline   Reply With Quote
Old 04-11-2011, 11:05 AM   #4
bbunt302's Avatar
I've always been able to get them out by using a jack to adjust the angles of the rear and prying until it hits the perfect angle. Can be a real PITA sometimes though.
Scary stuff.
Old 04-11-2011, 01:07 PM   #5
so the nut is off the bolt but the bolt wont come out? yea have to beat it out etc and as said gotta get the angle just right.
Old 04-11-2011, 10:57 PM   #6
Titus Wadicus
svtlx's Avatar
+1....the right angle, use a floor jack goin up and down till u find the right spot
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-14-2011, 06:04 PM   #7
thanks guys. anybody know where i can get justttt a new bushing without having to replace the whole trailing arm?
Old 04-20-2011, 08:52 PM   #8
i just cut the bolt. anyone know how to get that bushing out or if i could even get a replacement one?!
Front and rear control arm hardware specs SilentNoise 1979-1995 Mustang GT 2 10-13-2009 08:51 AM
rocker arm help rbhasychak 1979-1995 Mustang GT 4 08-14-2007 06:04 PM
Arm panels Matt'sredbeauty Mustang Parts for Sale and Wanted 7 05-31-2005 06:55 PM
Torque Arm for a 7.5 rear axle fastmustangs1 Pre-2005 V6 Mustang 6 02-17-2005 03:01 PM
01:42 AM
