| Re: M112?
it's not a complete kit. it's missing other brackets...crank pulley..injectors.. etc. im not sayn itsa bad deal. but itsa bad deal for a novice builder, or someone new to the world of boost.
if you cant look at it and know what's missing.... u most likely dont need to buy it.
its mostly an upgrade/jobber kit. for someone that already has a blower and most of the parts to swap over and make it fit.
you'll spend another 700-1200 tryn to find all the parts to get it on your car.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
