Automatic stuck in park..Help? - Mustang Evolution
Old 04-12-2011, 04:08 PM   #1
NeedSomeMods's Avatar
Ok guys, I have a problem.
The 2000 (v6, auto) is stuck in park.
After the motor blew itself up I parked it under a canopy in the driveway and unfortunately has been there like that for a while.
Now I need to move it (push out from underneath the canopy) but I can't get it out of park...
I can't even turn the key.
How can I get it into neutral?
Do I need to disconnect something?
Any help/advice would be greatly appreciated.
Thanks.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-12-2011, 04:29 PM   #2
I'm pretty sure there is a release next to the shifter. It has a cover that must be removed. Not positive since I don't have an auto.
11SHELBYGT500 is offline   Reply With Quote
Old 04-12-2011, 09:23 PM   #3
Is your wheel locked? Might jiggle the wheel back and forth while turning the key. Sometimes they get stuck like that.
93CobraGuy is offline   Reply With Quote
Old 04-12-2011, 09:34 PM   #4
Re: Automatic stuck in park..Help?
If you can't turn the key at all, I would also assume the steering wheel is locked.
You should be able to jiggle the steering wheel back and forth while attempting to turn the key to free it. I honestly don't know if there's an easy trick to undo it...
Old 04-12-2011, 09:53 PM   #5
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Yea, what they said. It's obvious you can't get it out of park with the ignition in the OFF position. But if it's in accessory and it still won't get out of park, make sure your foot is on the brake, and if not then it may be the brake switch.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 04-12-2011, 10:58 PM   #6
And make sure you have a charged battery in it when you do get the key to move. Also you can get under the car with it on jack stands and unbolt the shift linkage then shift the trans out of park WHILE someone is holding the brake.
Straublittleman is offline   Reply With Quote
idle stuck at 2k 01gt88vert 1979-1995 Mustang GT 1 04-12-2011 05:50 AM
Women Can't Parallel Park (and something about Ford's Active Park Assist) OsirisGuy The Bar 8 09-24-2009 09:03 PM
Im stuck on this song... Tbird232ci The Bar 1 08-03-2006 03:38 PM
Physics help... I'm stuck WhiteStang99 The Bar 21 02-16-2006 03:11 PM
Stuck on what stang to get:-\ The Arson The Bar 71 03-22-2005 09:36 AM
05:10 AM
