True or false - Mustang Evolution
Old 04-12-2011, 06:46 PM   #1
True or false
Someone from advance auto told me a v6 should not have cattless exhaust... Is this true?
Blackedout is offline   Reply With Quote
Old 04-12-2011, 06:54 PM   #2
MC770's Avatar
Re: True or false
If your talking factory it should have cats on it.
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 04-12-2011, 07:22 PM   #3
Re: True or false
It's not anything that will hurt the engine necessarily. I prefer cats on a V6.
You will notice a drop in low-end power with the removal of cats.
Old 04-12-2011, 07:31 PM   #4
Drop on low in power?
Old 04-12-2011, 07:31 PM   #5
Doesn't cattles improve hp and mpg
Old 04-12-2011, 07:34 PM   #6
Aftermarket
Old 04-12-2011, 08:24 PM   #7
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: True or false
If you remove your cats you will gain a CEL. The only way to get rid of that is by using something like an x-cal, MIL eliminators, or a dyno shop. The "gains" are negligible and unless you are running something like a turbo, you don't want to hear your v6 without cats.
*Gains is in quotes because all you are doing is moving hp from the low rpm band to the high rpm band.
DarkShadow is offline   Reply With Quote
Old 04-12-2011, 08:27 PM   #8
DarkShadow's Avatar
Re: True or false
Actually, catalytic converters are HIGHLY efficient nowadays. Leaps and bounds over what they were in the 70's, 80's, and even early 90's. I believe a few studies were done, unofficially, on our cars that proved you actually lose mpg by removing your cats because of the 3.8's need for that additional backpressure at city speeds.
Old 04-12-2011, 08:34 PM   #9
I have a tuner for my cel. And u think I should buy a catted x pipe ?
Old 04-12-2011, 08:51 PM   #10
Re: True or false
If you can live with the 4 stock cats I'd suggest keeping them and have the stock y-pipe removed to 2 divorced pipes.
If you want aftermarket hi-flow cats then a catted midpipe is a good option, but it is more expensive.
Old 04-14-2011, 01:34 AM   #11
Re: True or false
You need to remember how important keeping the proper back pressure is to the engine. Gradual increases help in scavenging exhaust gases out too. Superchargers and turbos are the exception, they require a full 2.5" exhaust.
Old 04-14-2011, 08:28 AM   #12
Re: True or false
True (due to it will not sound good)
Uhh.. True or not true? Ibanezplayer272 Pre-2005 V6 Mustang 12 05-04-2006 05:00 PM
Cop Gets owned for false ticket to camaro Falcon The Bar 16 03-12-2006 03:58 AM
could it be true oaktonarcher The Bar 7 01-26-2005 08:18 PM
this true STEVE The Bar 4 07-18-2004 12:32 PM
false tail pipes STEVE The Bar 9 05-22-2004 11:12 PM
01:19 AM
