Pulleys - Mustang Evolution
Old 04-12-2011, 08:04 PM   #1
Pulleys
There's these pulleys I'm looking at on rpmoutlet.com. Is getting underdrive pulleys a good upgrade? Like I heard stories to where the alternator couldn't charge bc of performance pulleys, anyone out there with experience?
Blackedout is offline   Reply With Quote
Old 04-12-2011, 08:31 PM   #2
Re: Pulleys
Udp's are a decent mod for the v6's. There are a few dyno sheets out there showing that the 25% pulley does offer some gains.
The only time you should consider not running a udp is if you have a large stereo system or plan on supercharging in the future.
I personally wouldn't order from RPM Outlet...I order my exhaust there back in 06 and had a bad experience. I've also heard other negative things regarding the place.
ASP makes the pulley, you could either order from them or check site sponsors...I'm believe CJ Pony Parts and Latemodel Restoration offer them for the 99-04 v6's.
Old 04-12-2011, 10:56 PM   #3
Re: Pulleys
yeah, I got the two piece kit from BBK that included the main drive pulley and the alternator pulley. People over react when an issue arises with installation of the under drive pulleys. All you have to do is monitor your at idle rpms after installing them. If its a little low, then adjust it up slightly to were it was originally around 900 rpms. Thats it! Its as simple as that. It takes 60 seconds to adjust the idle screw.
Pulleys! gasteven Pre-2005 V6 Mustang 16 04-15-2010 11:25 AM
Pulleys SaturnMan8227 Pre-2005 V6 Mustang 12 01-19-2009 02:18 PM
under pulleys sparkylarue Pre-2005 V6 Mustang 4 03-15-2008 01:07 AM
UD Pulleys mexor 1979-1995 Mustang GT 5 08-11-2004 06:46 PM
UD Pulleys RedDragonV6 Pre-2005 V6 Mustang 8 02-20-2004 12:29 PM
05:21 PM
