Hood - Mustang Evolution
Old 04-17-2011, 08:20 AM   #1
Hunter's Avatar
Hood
I have a 1995 V6. Will a newer hood from a 99-04 bolt right onto my brackets? What do you guys think about if I put on a mach 1 or GT hood onto a base model mustang?
_____________
Landis
Hunter is offline   Reply With Quote
Old 04-17-2011, 09:22 AM   #2
wereKEV's Avatar
Re: Hood
I don't know if it would bolt on your brakets you might have to fab new ones.
wereKEV is offline   Reply With Quote
Old 04-17-2011, 10:06 AM   #3
Hunter's Avatar
I dont want to cut my stock hood up for a hood scoop. It is in perfect condition other than needing paint. Making new brackets wouldnt be hard to do
_____________
Landis
Old 04-17-2011, 10:13 AM   #4
wereKEV's Avatar
Re: Hood
Making the brackets would be easy to do just test fit the hood you are trying first to make sure all the lines match up because if it messes up the lines of the car it's not worth it.
Old 04-17-2011, 10:14 AM   #5
Topless04GT's Avatar
Re: Hood
no no no they wont fit... its a 95... they are completely different shapes. Hope this helps
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 04-17-2011, 10:16 AM   #6
wereKEV's Avatar
Re: Hood
Like I said if the line of the hood does not follow thw lines of the car it will look tj ish.
Old 04-17-2011, 07:35 PM   #7
Re: Hood
Yah if you can make 99-04 hood fit a 94-98 without any fabbing I'd be very impressed.
Check out Latemodel Restoration an CJ Pony Parts, I remember seeing some good looking 94-98 hoods in their catalogs. The 96 cobra hoods look nice, as do the cowls.
Old 04-17-2011, 08:27 PM   #8
Hunter's Avatar
Re: Hood
Ya I just checked out a 2000 gt tonight and the hood brackets are the same but since the body lines are different. I don't see it fitting without some major fabricating.
_____________
Landis
Old 04-18-2011, 09:41 AM   #9
wereKEV's Avatar
Re: Hood
If it's possible to do and if you can get the lines right it would be a unusual modification.
Old 04-18-2011, 06:55 PM   #10
Hunter's Avatar
Re: Hood
Ya it would and I think I might try it. I need to do a little more looking at body lines and everything to see if it will work.
_____________
Landis
Old 04-18-2011, 09:02 PM   #11
Re: Hood
I think it'd be much easier to buy a 94-98 hood. You can put a 99-04 hood scoop on your car if you really wanted...I've seen them on sn95 cars, I personally don't think they fit the lines of the car, but it can be done.
They do make the Mach 1 shaker scoop kit for your year car too...you can cut the hole and have the functionl shaker scoop...those always look nice.
Old 04-19-2011, 08:09 AM   #12
Hunter's Avatar
Re: Hood
It would be more amusing to put that skaker hood on because people already think my car is a V8 but in reality it is a V6.
_____________
Landis
Old 04-19-2011, 10:07 AM   #13
wereKEV's Avatar
Re: Hood
That would be cool.
Old 04-19-2011, 10:53 AM   #14
Hunter's Avatar
Re: Hood
Ya it would. I do like that Idea. I think I might actually look into putting a shaker hood onto my V6. thanks for the idea!
_____________
Landis
Old 04-19-2011, 02:44 PM   #15
gixxer007's Avatar
Re: Hood
I think that would look nice to complete and do for sure.I agree with above buy a hood done already or the scoop to have a body shop do for you.
gixxer007 is offline   Reply With Quote
Old 04-19-2011, 02:59 PM   #16
Re: Hood
some companies make hoods that are made to fire pre 99 that are in the 99+ style, what style are you wanting?
Old 04-19-2011, 07:31 PM   #17
Hunter's Avatar
Re: Hood
I own a 1995 V6. I want a 04 Mach 1 hood or GT.
_____________
Landis
Old 04-20-2011, 07:59 AM   #18
Titus Wadicus
svtlx's Avatar
Re: Hood
if you are interested lemme know and i will look. but there is a company out there that makes a functional mach1 shaker for 94-98.... im not sure if they make it for the v6, but i know they make it for the 94-95 5.0
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-20-2011, 08:07 AM   #19
Hunter's Avatar
Re: Hood
Ya if you want that would be nice. I really think it would look nice on my mustang.
_____________
Landis
Old 04-20-2011, 08:21 AM   #20
Titus Wadicus
svtlx's Avatar
Re: Hood
cdc
classicdesignconcepts.com
248-624-7997
Old 04-21-2011, 09:09 PM   #21
Hunter's Avatar
Re: Hood
Thanks
_____________
Landis
Old 04-22-2011, 06:32 AM   #22
Jordan's Avatar
Re: Hood
i do not see a fully functional shaker intake on that site for a 94-98 mustang of any kind.
Red 1998 Mustang V6 5-Speed. Flowmaster True Dual Glasspack Exhaust, AM Cold Air Intake, Black Chrome Cobra 17x9 fronts, 17x10.5 rears, short throw shifter, rear bumper inserts, billet grill top and bottom with pony insert, chrome shorty antenna, chrome shift knob, halo headlights-HID's 8000k, smoked fog lights-HID's 8000k, custom radio and speakers, Eibach Pro-Kit lowering springs
Jordan is offline   Reply With Quote
Old 04-22-2011, 07:07 AM   #23
Titus Wadicus
svtlx's Avatar
Re: Hood
did u try calling or emailing them? they had a large write up with install instructions in 5.0 magazine. i got the info from the artical...
Old 04-22-2011, 07:13 AM   #24
Re: Hood
cervinis.com has good hoods, be careful who you go with quality matters
Old 04-23-2011, 09:24 AM   #25
Jordan's Avatar
No I didn't think of that. Maybe I'll give that a try. Thanks.
WTT: 00 R hood (opened louvers) for 03/04 Termi hood jimmy_beaner Mustang Parts for Sale and Wanted 14 07-05-2009 07:15 AM
FEELER: WTT 04 cobra hood for cowl hood SimplyOrange Mustang Parts for Sale and Wanted 18 08-16-2008 05:13 PM
'02 Black Mustang Hood w/ GT Hood Scoop mattstang Mustang Parts for Sale and Wanted 8 08-22-2006 09:11 AM
Hood Scoop + 04 base model hood Exit_In_Red Mustang Audio & Video 7 10-22-2004 06:10 PM
WTT: Redfire '03 V6/Cobra hood for GT hood w/ scoop tire Mustang Parts for Sale and Wanted 0 02-21-2004 10:07 AM
05:59 AM
