V6 power - Mustang Evolution
Old 04-18-2011, 07:40 PM   #1
Terry101's Avatar
V6 power
Can anyone tell me what the horsepower rating is for a '96 stang 3.8, and is that at the wheels or crank?
Terry101 is offline   Reply With Quote
Old 04-18-2011, 07:43 PM   #2
blackonblack's Avatar
Re: V6 power
i think 150 to wheels?
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 04-18-2011, 07:48 PM   #3
Biffdiesel's Avatar
Just search 96 v6 mustang specs
Biffdiesel is offline   Reply With Quote
Old 04-18-2011, 07:54 PM   #4
Terry101's Avatar
Re: V6 power
150 to the wheels? Thanx. Im adding cai, true duels, and sct eliminator chip. Hope I see a difference!
Old 04-18-2011, 07:56 PM   #5
Re: V6 power
nice yes you will. prob no more than 30 hp though
2004 3.9L v6
Old 04-18-2011, 07:59 PM   #6
Hunter's Avatar
Re: V6 power
The 3.8L are 145 HP
_____________
Landis
Hunter is offline   Reply With Quote
Old 04-18-2011, 08:01 PM   #7
Terry101's Avatar
Re: V6 power
Black on Black, & Landis , thanx guys I appreciate the help
Old 04-18-2011, 08:07 PM   #8
I have a 2000 v6 I have BBK cold air intake, PYPES offroad true dual exhaust, and I have an SCT tuner. I have a big big difference and so will u.
Blackedout is offline   Reply With Quote
Old 04-18-2011, 09:42 PM   #9
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: V6 power
Probably 138 RWHP if you put it on a dyno
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-18-2011, 09:56 PM   #10
Re: V6 power
94 and 95 3.8's were rated at 145 hp and 215 tq -crank
96-98 3.8's were rated at 150 hp and 215 tq - crank
You'd probably see ~ 120 rwhp on a dyno in stock form (based on 20% parasitic loss)
The basic bolt ons will wake the car up when compared to stock form, but won't add a ton of hp. The best mod you can do without doing forced induction or seriously building the engine is a 99+ swap, from single port to split port. The split port 3.8's (99-04) were rated at 190-193 hp and 220-225 tq...a much better starting platform.
Old 04-18-2011, 09:59 PM   #11
Joshy's Avatar
I need intake and tuner so bad. Lol. I just need a job first.
www.petom.biz
Joshy is offline   Reply With Quote
Old 04-19-2011, 08:50 AM   #12
Titus Wadicus
svtlx's Avatar
Re: V6 power
u sir are a plethora of information... i shoulda talked to you first. o well, now im v8ing it.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-19-2011, 09:03 AM   #13
Joshy's Avatar
Lol. Nice
www.petom.biz
Old 04-19-2011, 09:37 AM   #14
Re: V6 power
Sorry to post something opposed to previous info put up but the 94-98 single port V6 puts out 127HP to the flywheel. You can get the answer from any Mustang dyno shop. Just like alot of other people, I am quite positive thats the correct number. If interested, PM me and I can forward my dyno sheets to you no problem.
Old 04-19-2011, 09:38 AM   #15
Re: V6 power
Sorry, didn't see this post already up. (Sonicpony's posting is 100% right)^He is correct^Sonicpony always knows his sjit when it comes to V6 Mustangs. Always.
Old 04-19-2011, 09:50 AM   #16
Re: V6 power
94/95 was 145hp in 96 they got a huge boost up to 150hp. This is the hp at the engine. The Tq is 225 at the engine.
Take 17.5% of that off for rear wheels IF manual transmission and 22% if automatic.
Automatic Transmission 3.8L 1996 Mustang
Engine: 150hp/225tq Rear Wheels: 123rwhp/185rwtq
5-speed Transmission 3.8L 1996 Mustang
Engine: 150hp/225tq Rear Wheels: 115rwhp/175rwtq
power renemeza100 1996-2004 Mustang GT 4 03-21-2011 01:25 PM
no power!! sledgehammer 1979-1995 Mustang GT 2 03-16-2008 10:56 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 07:40 PM
better for power? tedness Pre-2005 V6 Mustang 12 01-07-2005 09:29 PM
Power Seph The Bar 22 05-14-2004 03:30 PM
06:58 PM
