Lower Control Arms - Mustang Evolution
Old 04-23-2011, 11:59 AM   #1
Hunter's Avatar
Lower Control Arms
I want to put new lower control arms but I am not sure what kind I should get. Anyone have a ideas? 1995 3.8L coupe base
_____________
Landis
Hunter is offline   Reply With Quote
Old 04-23-2011, 12:10 PM   #2
bbunt302's Avatar
Maximum Motorsports are the best on the market IMO.
Scary stuff.
Old 04-23-2011, 12:17 PM   #3
Hunter's Avatar
Re: Lower Control Arms
Do I actually have to install a coil over kit in for putting tubular control arms in?
_____________
Landis
Old 04-23-2011, 12:53 PM   #4
bbunt302's Avatar
Are you talking tubular A-arms or rear lower control arms? With rear LCAs there is absolutely no reason you should have to have coil overs.
Scary stuff.
Old 04-24-2011, 08:14 PM   #5
Hunter's Avatar
Front lower control arms. The aftermarket tublar A arms. All the ones i have found call for a coil over kit which I don't want or need for my mustang as a daily driver
_____________
Landis
Old 04-25-2011, 08:28 AM   #6
no need for coil overs, just need the LCA and if you wish you can replace the shocks while you are at it.
To get the best bang do some springs as well.
Old 04-25-2011, 03:41 PM   #7
DarkShadow's Avatar
Send a message via AIM to DarkShadow
For the front, they are called A arms. Because they are in the shape of an A. There is also no lower or upper. Just an arm as all that is above is the strut mounts.
For the rear, those are control arms and they are differentiated because you have a total of four, two above in relation to the rear end and two below, hence LCA, UCA.
Now since you are talking front, you can get the tubulars with spring perches to utilize the stock MacPherson set up, but truly, in my humble opinion, you will be spending a decent chunk on something that will net you no real geometry improvements. What you will be looking at will be a little bit of weight reduction in front, which will be reduced due to the addition of spring perches, and some rigidity in the new arms. That's about it.
DarkShadow is offline   Reply With Quote
Old 04-26-2011, 08:48 PM   #8
Hunter's Avatar
Yes I do understand stand that. Getting new stock ones or getting after market tublar a arms is about the same price i have found.
_____________
Landis
Old 04-27-2011, 08:31 PM   #9
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
UPR is decent and affordable
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-28-2011, 11:49 AM   #10
^^ decent is right, on a budget they are not bad overall and usually rip off others designs and use the same thing on many parts
Old 04-29-2011, 06:52 AM   #11
Hunter's Avatar
Alright Thank you
_____________
Landis
Old 04-29-2011, 08:18 AM   #12
no need to go CRAZY and buy the best of the best if you never plan to autox or drag race. The issue is quality, you dont want to buy a part that wont fit or that breaks.
Old 04-29-2011, 04:53 PM   #13
Agreed....that's why I only said "decent". They have been proven to work fine, and they're afforable.
-Will
Old 05-02-2011, 09:54 AM   #14
Hunter's Avatar
Thanks Will.
_____________
Landis
J&M Lower Control Arms Great White ME Site Help & Announcements 2 01-18-2011 06:46 PM
Adjustable Lower Control Arms matthews.stang Pre-2005 V6 Mustang 6 07-10-2007 06:17 PM
Hotchikus lower control arms question dana 1979-1995 Mustang GT 14 02-03-2006 07:58 PM
which lower control arms to get? mild2002gt 1996-2004 Mustang GT 11 01-17-2005 12:54 AM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 04:43 PM
01:33 AM
