Nos - Mustang Evolution
Old 04-25-2011, 11:26 AM   #1
Nos
I have a 2000 v6, What do I have to do to my car for it to be able to run on 75 shots of nos?
Blackedout is offline   Reply With Quote
Old 04-25-2011, 11:31 AM   #2
Region: Arkansas
As I understand from research, our engines can handle up to a 100 shot without severe damage.
All nitrous shortens your engine's lifespan and any setup ever made has the potential to catastrophically fail, even race setups professionally installed.
Keep in mind what you want the nitrous for, if it's just to show off you'll end up ditching it later (everyone I know has). If it's for frequent racing (track or light-to-light raping ricers if that's your prerogative) go for it but remember there's no guarantee it won't fail.
I suggest doing a lot of research on nitrous injection systems, how they work, what they're designed for, etc before committing money to get one.
That's all just my opinion, heed it if you so desire.
BackPressure is offline   Reply With Quote
Old 04-25-2011, 02:15 PM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Nos
To the OP:
STOP saying NOS. NOS is a brand of Nitrous Oxide kits...it is not synonymous with NO2 (nitrous oxide). It's a little street jargon that the fast and the furious generation uses.
As for safety of Nitrous, nearly any part of your engine at any time can catastrophically fail weather nitrous is involved or not. Properly tuned (stock) motors with the size shot that the bearings and seals can handle (as well as other rotating assembly parts) will more than likely last longer than a Forced induction motor. If you don't go cheap on the kits and get the additional safety features (that you probably can't even get kits without anymore), don't exceed the size shot that others who USE nitrous say is within the motor's safe limits, change timing/swap plugs as recommended, fuel safety, etc, the only real drawback is keeping the bottle filled.
DarkShadow is offline   Reply With Quote
Old 04-25-2011, 05:38 PM   #4
Re: Nos
Originally Posted by DarkShadow View Post
To the OP:
This!
I ran a 75 shot on an old '88 Honda Accord, stock engine, 270K miles. Never blew up, and ran about 12+ 10lb bottles through it. You should be good for a 75 shot I'd say. Nitrous is just as safe as forced induction. You just have to use it the right way. Do some research for sure. Grab a ZEX kit, or Nitrous Express. RESEARCH!!! Can't say that enough.
93CobraGuy is offline   Reply With Quote
Old 04-25-2011, 05:50 PM   #5
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Nos
N2O.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 04-25-2011, 06:10 PM   #6
Titus Wadicus
svtlx's Avatar
Re: Nos
intercool = aftercool....lol.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-25-2011, 06:23 PM   #7
Re: Nos
yea nice question anymore info appreciated
3.8boii is offline   Reply With Quote
Old 04-25-2011, 07:45 PM   #8
Titus Wadicus
svtlx's Avatar
Re: Nos
everette and 93cobra are two ppl u could talk to bout it.
Old 04-25-2011, 07:51 PM   #9
DarkShadow's Avatar
Re: Nos
Originally Posted by MarkuzLS1 View Post
N2O.
lol, hurp a durp
Old 04-25-2011, 09:04 PM   #10
Dope
Old 04-25-2011, 09:05 PM   #11
Lol that's what the people at the track call it
Old 04-25-2011, 09:10 PM   #12
Still never figured that one out
Old 04-25-2011, 09:28 PM   #13
Titus Wadicus
svtlx's Avatar
Re: Nos
cause u inject it into ur car like heroine...lol.
Old 04-25-2011, 09:40 PM   #14
Never did a drug in my life so I wouldn't know I sound like a complete idiot I think it's time for bed
NX vs nos GT773 2005-2010 Mustang GT 12 06-26-2009 12:34 PM
NOS Zebs5408 Pre-2005 V6 Mustang 4 05-30-2009 08:20 PM
Where can I get a NOS/NX? Stang01 Pre-2005 V6 Mustang 23 07-29-2003 09:07 PM
How much NOS/NX shot wont F me up Stang01 Pre-2005 V6 Mustang 8 07-26-2003 08:35 AM
06:26 AM
