ud pulleys - Mustang Evolution
Old 04-25-2011, 10:02 PM   #1
blackonblack's Avatar
ud pulleys
with summer comes a job. figured id get a little somethin for my car. i know the gains arent crazy..
i was lookin at this asp one. looks like it comes with everything Mustang ASP Underdrive Pulleys & Belt Package
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 04-25-2011, 10:10 PM   #2
Re: ud pulleys
That's probably the one I'd go with...ASP makes a good product and there are dyno results backing up claimed gains.
Old 04-25-2011, 10:13 PM   #3
Re: ud pulleys
good to hear. thinking about this h-pipe as well..MAC Off Road H-Pipe for all 99-04 V6 Mustang
which would you say to get 1st...h pipe or udp?
2004 3.9L v6
Old 04-25-2011, 10:26 PM   #4
Re: ud pulleys
Depends on what you want:
UDP - mainly an engine mod that will gain some hp and tq
H pipe - slight power gains and major change in sound...keep in mind that particular h-pipe is for stock or shorty headers. You need the shorter h-pipe if you want long tubes.
Old 04-25-2011, 10:31 PM   #5
Re: ud pulleys
not sure which i want 1st lol. gonna think on it.
i have stock headers. itll hook up fine to y pipe super40s?
2004 3.9L v6
Old 04-25-2011, 10:36 PM   #6
Re: ud pulleys
If you get the h-pipe you posted above, it will bolt right up to your stock headers, but you'll have to fab up some pipes for it to work with your current flows. If you still have the y-pipe then you'll have to get it removed and fab up 2 separate pipes to the h-pipe from the flowmaster's pipes.
Old 04-25-2011, 10:38 PM   #7
Re: ud pulleys
where do i need to go to get these pieces made?
2004 3.9L v6
Old 04-25-2011, 10:41 PM   #8
Re: ud pulleys
A decent exhaust shop should be able to do it no problem...and it shouldn't take very long to do.
They would cut out the stock y-pipe, install the new h-pipe, then weld 2 sections of pipe from the h-pipe to the piping leading to the mufflers.
I wouldn't imagine it taking longer than an hour to do, so don't let an exhaust shop gouge you. If you have a trusted mechanic he might be able to do it too if he has some extra piping lying around.
Old 04-25-2011, 10:44 PM   #9
Re: ud pulleys
now last question. after all this for the hpipe itself, 2 pieces, and installation how much $ do you think im lookin at? to decide whick mod i get 1st..
2004 3.9L v6
Old 04-25-2011, 10:52 PM   #10
Re: ud pulleys
H-pipe: 180
Install and Piping:80-150+ (Depends on shop and rates)
Total: 260-400
It really depends on the labor charge and materials charge from the shop.
I'd say the h-pipe will cost more than the udp. Are you installing the udp yourself or having it installed?
Old 04-25-2011, 10:55 PM   #11
Re: ud pulleys
installing upd myself. hard decision. i just know once i get one of these mods, im going to wait a good while to do the other. i want the hp/torque gains.. but im also ready for a new sounds and some flow
2004 3.9L v6
Old 04-25-2011, 11:00 PM   #12
Re: ud pulleys
Yah you probably picked the 2 worst mods to compare, lol.
One is strictly power and the other is strictly sound/flow.
You could always get the udp first, install it yourself and have the stock y-pipe cut out and 2 divorced pipes in place of it to your mufflers...that will make the 6 a little bit louder. It won't take too much to fit the h-pipe in later. It also won't break the bank, shouldn't be more than an hour's labor to do it. This way you'd get a little bit of both worlds
Old 04-25-2011, 11:08 PM   #13
Re: ud pulleys
i might just go for both this summer. either way i see these as my last mods...but then again i said that after the gears
2004 3.9L v6
Old 04-25-2011, 11:10 PM   #14
Re: ud pulleys
haha ain't that how it always goes
Old 04-26-2011, 08:18 AM   #15
Re: ud pulleys
those work pretty good, say 5rwhp/tq or so and they help mileage a bit... they can hurt by dimming the lights while stopped at night a bit and if you have a system it might be a bit of a strain.
Its not just an easy bolt on though you have to take the harmonic balancer off so basically you need air tools.
Old 04-26-2011, 01:11 PM   #16
Re: ud pulleys
well i was hoping it was an easy bolt on. but i talked to a friend last night that installed an xpipe an 14inch magnaflow to his land rover. did his own welds and says he can fab the 2 pieces for my car(but ill prob just have a shop do the pieces and me and my friend install). so im going for the H pipe. im really excited.
if i can sell my amp for my old subs (kenwood 600w) ill be in good shape for summer projects.
2004 3.9L v6
Pulleys Blackedout Pre-2005 V6 Mustang 2 04-12-2011 11:56 PM
Pulleys! gasteven Pre-2005 V6 Mustang 16 04-15-2010 12:25 PM
Pulleys SaturnMan8227 Pre-2005 V6 Mustang 12 01-19-2009 03:18 PM
under pulleys sparkylarue Pre-2005 V6 Mustang 4 03-15-2008 02:07 AM
UD Pulleys RedDragonV6 Pre-2005 V6 Mustang 8 02-20-2004 01:29 PM
12:02 PM
