repaired - Mustang Evolution
Old 04-29-2011, 02:46 AM   #1
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Exclamation repaired
got the y-pipe and cats had to get the whole thing car shakes with no engine light and when i mess with the a/c it calms down does anyone know what and if so how to make it stop
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 04-29-2011, 02:01 PM   #2
DrMentalX's Avatar
Re: repaired
Did you reset the computer?
DrMentalX is offline   Reply With Quote
Old 04-29-2011, 02:25 PM   #3
Re: repaired
you plug in the sensors?
Old 05-02-2011, 03:49 PM   #4
00STANG00's Avatar
Exclamation Re: repaired
it was shaking before i got the work done sencers are connected. people tell me it needs a tune up but already had one.
SUCK MY DUST
Old 05-03-2011, 09:09 AM   #5
Re: repaired
Missed something in the "tune-up list" maybe? Fuel filter, air filter, Seafoam intake, are you at 900 RPM when at idle? Do you have UD Pulleys?
Old 05-03-2011, 01:53 PM   #6
00STANG00's Avatar
Re: repaired
idk i will have to check they dont put new spark plug wires in so wonder what else they didnt do. when car running and in park its like a earthquake in there
SUCK MY DUST
Old 05-03-2011, 10:42 PM   #7
Re: repaired
One last thing thats easy to check and directly effects rough idle is a vacuum leak on the 3 lines of tubing in and out of the EGR valve. They get brittle and crack easy from engine heat. There is usually two lines ran together and then a third line from the EGR valve going into the upper intake manifold. But I would bet its a loose or bad plug or same with the wires (loose on ign coil or plug)
02:18 PM
