fox v6 - Mustang Evolution
Old 04-29-2011, 06:54 PM   #1
calypso coupe's Avatar
fox v6
putting 03 v6 in 93 coupe. will a 93 t5 work and not give me computer issues.
want to keep stock gauges and dash.
calypso coupe is offline   Reply With Quote
Old 04-29-2011, 07:13 PM   #2
Titus Wadicus
svtlx's Avatar
Re: fox v6
it will all work fine.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-29-2011, 08:03 PM   #3
Re: fox v6
good i will be picking up my world class t5 sun. need to get some other parts then i will dissasemble the 03.
thanks for the help.
Old 04-29-2011, 08:05 PM   #4
Re: fox v6
then after all bugs worked out its off to paint and custom shop. will post pics as soon as i can.
What's up fox Afterhours 1979-1995 Mustang GT 8 01-06-2011 12:22 PM
94 v6 - VS - Fox 5.0 sledgehammer Pre-2005 V6 Mustang 1 03-04-2008 04:44 PM
Someone with a fox.... fast64 Mustang Wheels & Tires 1 12-26-2007 08:00 PM
Might be getting another fox soon.. MonteCitan The Bar 29 04-14-2005 09:19 PM
What ya think of this Fox? lowflyn The Bar 29 01-22-2005 09:50 PM
09:45 PM
