AIR IDLE CONTROL - Mustang Evolution
Old 05-02-2011, 11:00 AM   #1
CHILE10_STANG's Avatar
Exclamation AIR IDLE CONTROL
MY CARS RPMs ARE AT 2 WHEN I PUT MY CAR IN PARK AND WHEN I CHANGE TO DRIVE IT PULLS HARD - A COUPLE MONTHS AGO WHILE AT FORD, MY FRIEND (WHO IS A MECHANIC THERE) SAID I WOULD HAVE TO CHANGE THE AIR IDLE CONTROL SOON... AND I FEEL SOON IS "NOW!"
HAVE ANY OF YOU CHANGED YOUR AIR IDLE CONTROL?
MY CAR IS A 2000 V6
THANKS!
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 05-02-2011, 11:02 AM   #2
ColeJohnson's Avatar
You might want to check your TPS as well.
Oh and check your caps lock key.
2016 Comp Orange GT (current)
Old 05-02-2011, 11:16 AM   #3
Re: AIR IDLE CONTROL
It's called the idle air control or IAC for short.
I'd recommend pulling it off (2 bolts) and cleaning it first. It's located on the throttle body, two bolts holding it in place, with one connector plugged into it.
Old 05-02-2011, 11:18 AM   #4
Titus Wadicus
svtlx's Avatar
MY CAR IS A 2000 V6
THANKS!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-02-2011, 12:02 PM   #5
Send a message via Skype™ to Texastboneking
lol
Texastboneking is offline   Reply With Quote
Old 05-02-2011, 12:12 PM   #6
thanks!
and my bad guys... its a habit!
its it possible that the idle air control is the one giving me problems?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-02-2011, 12:21 PM   #7
thanks!
it is. surely your check engine light is on. get the codes off it.
Old 05-02-2011, 12:33 PM   #8
Titus Wadicus
svtlx's Avatar
cole suggested you check the tps....
air silencer and spectre air filter brentmustanggt 1996-2004 Mustang GT 3 08-25-2010 08:39 AM
2000 V-6 Idle air control noise spgeid Pre-2005 V6 Mustang 3 06-17-2010 08:23 PM
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 08:44 AM
Mass Air Flow and Cold Air Intake Mike's-stang Pre-2005 V6 Mustang 1 08-20-2004 10:24 AM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 02:54 AM
11:28 AM
