tranny cooler - Mustang Evolution
Old 08-13-2007, 06:00 PM   #1
tranny cooler
we are in the process of installing a b&m tranny cooler in my car. the screw that comes out the bottom and top of the radiator has too much blank thread and we cant get the pieces supplied to catch b/c the threads on that arent deep enough.
for those that have installed them on these cars before, what is the fix for it?
Kyle is offline   Reply With Quote
Old 08-13-2007, 07:57 PM   #2
Re: tranny cooler
long zip ties will do the job if you cant bolt it up.
Old 08-13-2007, 10:34 PM   #3
Re: tranny cooler
We got it for the record.
Old 08-13-2007, 10:46 PM   #4
Re: tranny cooler
Damn...that was a quick trip.
And spector...Zip ties wouldn't cut the mustard. What we needed to connect was the transmission line to a hose adapter. Zip ties wouldn't seal the connection...as it was a compression fitting we were trying to connect.
It boils down to the fact that I don't think kyle trusted Brad and I...then again, we have been giving him a pretty hard time every chance we can. I think Kyle is going to be happy when Brad leaves town.
Old 08-13-2007, 10:48 PM   #5
Re: tranny cooler
Me, give him a hard time? Never.
BTW Kyle...might want to check those again tomorrow, I think I saw a drip....lol
Old 08-13-2007, 10:49 PM   #6
Re: tranny cooler
And rob...I wasn't even mean to him on the way back. He pulled up beside me at a redlight and I had the perfect chance to egg him on, but I didn't.
Kinda wanted to see if he'd follow our advice and not get on it tonight.
Old 08-13-2007, 10:55 PM   #7
Re: tranny cooler
If you would have egged him on...he would have responded and we would have been discovering every possible leak there could be...as well as towing him back to the house.
Old 08-14-2007, 07:14 AM   #8
Re: tranny cooler
duct tape would have held it just fine... if its good enough for a trip to the moon then its good enough to hold some line on a vehicle.
Old 08-14-2007, 08:45 AM   #9
Herbstang's Avatar
Re: tranny cooler
Trust in Rob and Brad Kyle !!!!! They would never lead you into harms way or do anything to hurt the mighty 3.9
Old 08-14-2007, 08:49 AM   #10
Herbstang's Avatar
Re: tranny cooler
Just for you Kyle
Next you should see that the fitting that B&M provides for hook up to the stock cooler lines will not work.
The threads on the stock flare nut start too far up and the provided fitting is too short. You can try finding another fitting with longer threads, that would work. I could not find one, so I did it this way.
First, bend the cooler line a little towards the outside of the car, this will provided a better angle. Then, cut the tranny cooler line just after the stock flare nut. Then place the new flare nut on the tranny cooler line. Next take the flare tool (very easy to operate) and flare the new end of the cooler line. You can now wrap the new flare nut fitting with teflon tape and screw on the B&M fitting. Make sure it is nice and snug. We don't want no leaks!!! Then attach the other hose from the cooler to the fitting you just assembled. Secure with a hose clamp.
Start the car and look for leaks. Let is run for a couple minutes. If they are any, fix them!. You are done!
Old 08-14-2007, 08:59 AM   #11
Re: tranny cooler
Well, we did hook the cooler up to his power steering at first...so he had the worlds first power steering cooler for those serious autocross days.
He face was priceless when he pulled off the ramps and had no power steering...I think he thought we destroyed his car.
Old 08-14-2007, 09:38 AM   #12
Herbstang's Avatar
Re: tranny cooler
another kodak monent missed
Old 08-14-2007, 09:41 AM   #13
Re: tranny cooler
And, in case anyone searches later...we found the proper fitting at oreily's. It is a 5/8 ths female fitting...it was located in the isles and not behind the desk. It is in the section where all their other fittings are.
Just for you Kyle
Old 08-14-2007, 06:00 PM   #14
Re: tranny cooler
i trusted y'all.......brad kept ****in with me making me second guess everything
Old 08-14-2007, 07:08 PM   #15
Re: tranny cooler
That's half the fun of it.
BTW, did you hear that squeaking in the rear after we bottomed out going into O'Reilly's?
Old 08-14-2007, 08:56 PM   #16
Re: tranny cooler
no
Old 08-14-2007, 10:03 PM   #17
Re: tranny cooler
Haha...just giving you a hard time man.
Old 08-18-2007, 05:37 PM   #18
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: tranny cooler
Is it the B&M with a fan attached? If so, that's the one I have and we had to do a combo of fittings to get it to work. But nothing major, just make sure all the threads were Teflon taped.
DarkShadow is offline   Reply With Quote
Old 08-18-2007, 08:56 PM   #19
Re: tranny cooler
it was just a B&M without the fan....
what size tranny cooler powerhungry966 Pre-2005 V6 Mustang 6 01-26-2006 09:00 AM
tranny cooler STEVE Pre-2005 V6 Mustang 10 07-10-2004 08:30 PM
Tranny Cooler is in Brent Pre-2005 V6 Mustang 16 06-22-2004 04:06 PM
tranny cooler?? Falcon Pre-2005 V6 Mustang 11 11-17-2003 06:51 AM
10:17 AM
