engine code help needed - Mustang Evolution
Old 05-05-2011, 11:51 AM   #1
kickerofdoom's Avatar
Po401 code what could it be
Old 05-05-2011, 11:53 AM   #2
Re: engine code help needed
EGR issue? we have a table somewhere with those here, let me see if i can find them
also http://www.obd-codes.com/p0401
Old 05-05-2011, 11:55 AM   #3
P0104 - Mass or Volume Air Flow Circuit Intermittent
Old 05-05-2011, 11:59 AM   #4
MAF issues...if the car is surging or running rough you might be in need of a new MAF or EGR...it could be the DPFE sensor that needs to be replaced, that measures the exhaust gases traveling thru the EGR.
Old 05-05-2011, 12:31 PM   #5
a maf is easy to clean you can try that to see if it gets better etc, its easy to replace as well go to a junk yard and yank one lol should be cheap
Check engine code- p1443 embecker Pre-2005 V6 Mustang 7 05-12-2014 12:22 AM
P0301 engine code White Stalion Pre-2005 V6 Mustang 7 01-19-2011 08:26 PM
check engine light misfire code 98stang460 1996-2004 Mustang GT 6 07-27-2010 08:27 AM
check engine light code help p0102 HELP! slow98gt 1996-2004 Mustang GT 1 05-21-2009 01:52 PM
engine code p0102 and p0113 BigL34461 Pre-2005 V6 Mustang 1 11-01-2006 05:49 PM
12:31 AM
