Is my Clutch okay? - Mustang Evolution
Old 05-05-2011, 04:39 PM   #1
blue-saleen's Avatar
Region: Utah
Is my Clutch okay?
So I installed the mm clutch lowering kit and I do not know if I need to change where my clutch engages. Here are the details:
Before lowering my pedal, the clutch engaged more towards the top of the pedal. I installed the kit and lowered the pedal as low as it would go. It ended up being lower than the brake pedal, and almost even with the dead pedal. The car started but I could not put it into gear. So I raised the pedal until it was even with the brake pedal. Now the car starts, and I can get it into gear, but it is engaging almost right off the floor. I took the car out and at about 55mph while giving it some gas I pushed in the clutch until my rpms started to raise. It is difficult to say, but it felt like I had to push the clutch in almost half way (which isnt that far considering its height).
So do I need to worry about changing where it engages?
blue-saleen is offline   Reply With Quote
Old 05-05-2011, 05:03 PM   #2
Yep. The only way that you're gonna get it where you want it is a firewall adjuster and possibly an adjustable cable. You still might need to set it higher still. Some clutches take more travel anyways.
Alscobra is offline   Reply With Quote
Old 05-05-2011, 05:16 PM   #3
Region: Utah
Re: Is my Clutch okay?
I have the adjustable cable (the one at the firewall doesn't seem to work...)
So where exactly do I want it, if not where it is already?
Old 05-05-2011, 05:24 PM   #4
Some clutches take more travel. You may have to adjust that pedal higher. You have to make sure the clutch is fully released when you let up. Just the slightest tension on the tob.
Old 05-05-2011, 05:28 PM   #5
Region: Utah
How will I be able to tell? Just the tension at the top?
Old 05-05-2011, 05:33 PM   #6
Yup. Set it to where there is no freeplay and just a little more tension.
Old 05-05-2011, 05:38 PM   #7
Region: Utah
Can I do that by changing the engagement more towards the top of the pedal (or can it only be done by raising the pedal back up because that would defeat the purpose of lowering the pedal...)
Old 05-05-2011, 05:46 PM   #8
You may be able to do it with an aftermarket quadrant. But idk about your exact set up.
Old 05-05-2011, 06:02 PM   #9
Region: Utah
Hmm, it feels like I don't meet any resistance until about 1/3 of the way in... :/
Need Clutch Help!!!! jkaminski24 1996-2004 Mustang GT 21 05-05-2010 09:43 AM
I think i need a new clutch SaturnMan8227 Pre-2005 V6 Mustang 11 01-31-2010 10:25 AM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 12:54 PM
clutch? roach 1996-2004 Mustang GT 5 03-23-2007 02:58 PM
clutch help mtchll50 1979-1995 Mustang GT 9 09-10-2006 08:09 AM
04:22 AM
