Throttle Body on my v6 2003 mustang - Mustang Evolution
Old 05-08-2011, 08:41 PM   #1
nyheyman's Avatar
My son decided to put a Throttle Body on my v6 2003 mustang while I was away for the weekend. The only non-stock ad on was a cold air intake I had on it. Well surprise the car runs like crap. I went through all the steps with him to see if he did something wrong but everything looks OK. Do I need to run a diagnostic to get it running right after such an ad on? Any help would be great before I have to run it to a shop.
nyheyman is offline   Reply With Quote
Old 05-08-2011, 10:03 PM   #2
Im no genius but I think it may be that your pushing to much air and not enough fuel to even the ratio, I think you can just tune it or something to get the ratio back to what it was stock but just in larger proportions.
Bongstang1 is offline   Reply With Quote
Old 05-08-2011, 10:07 PM   #3
Send a message via Skype™ to Texastboneking
Re: Throttle Body on my v6 2003 mustang
i think you just need a tune to make that throttle body run with that car. your car aint used to seeing that much air running into it. does it idle fine?
Texastboneking is offline   Reply With Quote
Old 05-09-2011, 06:03 AM   #4
nyheyman's Avatar
Now that you mention it; it does idle high and when you drive it there no real power. You push the pedal down and it slowly accelerates.
Old 05-09-2011, 06:22 AM   #5
Pretty sure you need a tune
Old 05-09-2011, 06:32 AM   #6
nyheyman's Avatar
Thanks
I'll let you know how it goes
Old 05-09-2011, 08:20 AM   #7
well the throttle bodies on the 3.8L anywhere near stock are not going to do anything if you can get your money back just put the stock one back on and save you some money as they dont make any gains unless you are over 350rwhp or so.
Old 05-09-2011, 11:25 AM   #8
wereKEV's Avatar
yep a tune would probably do the trick.
wereKEV is offline   Reply With Quote
Old 05-09-2011, 02:24 PM   #9
SilverPony's Avatar
Send a message via AIM to SilverPony
How long have you drove it since it got the tb? It can take some time for your car to adjust all the air coming in. If not then a tune will do it for sure.
-- 2011 Mustang V6
SilverPony is offline   Reply With Quote
Old 05-10-2011, 01:52 PM   #10
It probably will work its self out as the computer adjusts to it. But I don't think a shop will want to promise anything until you have the upper intake ported out to the same diameter as the TB itself.
Old 05-10-2011, 08:05 PM   #11
nyheyman's Avatar
Found out the TPS sensor was bad; replaced it and it runs great again. Just need to keep my son from under the hood! LOL
Thanks guys for all the help!!
Old 05-11-2011, 03:22 AM   #12
Awesome! Good deal. Sounds like your sons intentions were outstanding though. Father+Son+Mustang=
Old 05-11-2011, 08:38 AM   #13
Keep in mind the older engines like the 94-04's don't have the learning capablilities like the newer +2010's. They need the physical tune to adjust parameters correctly. It would've definitely been nice if that technology was used on those mustangs, but it wasn't, so they need some human assistance.
To the OP, glad to hear it was something miniscule. Now you can get back on the road with peace in mind.
Old 05-11-2011, 09:10 AM   #14
wereKEV's Avatar
we learn by our mistakes.
Old 05-12-2011, 01:53 AM   #15
SilverPony's Avatar
Oh, did not know that, thanks.
-- 2011 Mustang V6
Old 05-12-2011, 08:10 AM   #16
if you keep having trouble just take it off, you are not gaining anything by having it other than trouble.
Old 05-12-2011, 10:00 AM   #17
wereKEV's Avatar
yeah I would just put the stock one back on .
Old 05-14-2011, 12:38 AM   #18
austinknoll's Avatar
U guys helped me I was thinking on getting a tb but not anymore!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
2003 mustang
Throttle body Jettin Stang 1979-1995 Mustang GT 2 05-05-2011 06:55 PM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
$150 For Sale NEW BBK 70mm throttle body for 3.8L V6 2001-2003 bumlebee Mustang Parts for Sale and Wanted 2 07-31-2004 09:54 AM
95 v6 mustang throttle body tealstangman Mustang Parts for Sale and Wanted 8 03-17-2004 11:19 PM
08:13 PM
