The next upgrade... - Mustang Evolution
Old 05-09-2011, 05:34 AM   #1
The next upgrade...
I'm going to buy some blue h&r lowering springs or maybe some new tires... Need new tires bad...
Blackedout is offline   Reply With Quote
Old 05-09-2011, 06:35 AM   #2
Tib
Tib's Avatar
Re: The next upgrade...
i would get tires and the springs at once...so that way you can get everythind done at the same time plus a alignment...don't want to ruin the new tires.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 05-09-2011, 08:19 AM   #3
which are "blue" the super sports?
Old 05-09-2011, 11:06 AM   #4
kickerofdoom's Avatar
If you get those spring you will need c&c plates and maybe some new shocks
Old 05-09-2011, 09:48 PM   #5
The Super Sports...same color blue as the tokico HP's, more of a bright atlantic blue.
Yah definitely buy the tires and springs near the same time so you can get an alignment and not wear those nice new tires unevenly.
+1 on the CC plates, the Super Sports are going to give you a +1.6" drop in the front (more if you leave out isos) and the CC plates will make compensating and aligning much easier. Plus if you decide you want to hit the track course and want to adjust some parameters, you can.
Old 05-10-2011, 08:13 AM   #6
Just a suggestion because I have been researching it like crazy and asking people like sonicpony and those over at project47.com- The caster camber plates will be needed but the Steeda X2 Ball Joints really come in handy dropping the extra 1/2" up front to give the proper rake or stance. If the springs are not specifically rated for the V6 (which is 100lbs lighter than V8) you don't get as much of a drop in the front.
Old 05-10-2011, 02:45 PM   #7
1ijack's Avatar
Send a message via Yahoo to 1ijack
I made the mod on my 99 gt and it made a huge difference on the handling. The only thing lacking are the ball joints and bump steers. But the super sport springs and cc plates are a huge improvement over stock.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 05-10-2011, 10:37 PM   #8
Yes very true..I noticed that too when I installed the X2's. If you go with a spring that isn't specifically rated for the v6 like the H&R's and Eibachs the X2's and removing isos will lower it noticeably more.
Keep in mind both of these methods are optional (though new ball joints never hurt, especially if your car has higher miles).
Old 05-11-2011, 07:42 AM   #9
if you need tires then you have your answer, dont cause a wreck or something
Old 05-11-2011, 07:55 AM   #10
I'm getting gears first this month and tires next month. And installing gears after that...
Old 05-11-2011, 09:40 AM   #11
wereKEV's Avatar
the 2006 I have has blue sprins in the rear I don't know if they are lowering springs or something else they were on it when I got it.
wereKEV is offline   Reply With Quote
Old 05-11-2011, 01:00 PM   #12
shaqfu's Avatar
what gears are you getting?
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 05-11-2011, 02:12 PM   #13
3.73 for an AUTOMATIC....
Old 05-11-2011, 02:24 PM   #14
shaqfu's Avatar
I am still confused by the 3.73 vs 4.10 for autos, I have seen conflicting reports.... whats the difference?
work in progress...
Old 05-11-2011, 03:34 PM   #15
the reason 4.10 for auto is the auto is geared worse, so you are at lower rpms due to the transmission gears, the extra gearing 4.10 vs 3.73 give you help to even out the worse gearing the auto has vs the manual~ but the final drive gears isnt that much different so you may end up with a final drive higher rpms with 4.10s~
Old 05-11-2011, 04:35 PM   #16
shaqfu's Avatar
ok so not to thread jack any more than i already have, but are you saying the 4.10 is the better choice for auto? I see Blackedout was going with 3.73s....
work in progress...
The next upgrade... Blackedout Pre-2005 V6 Mustang 6 04-06-2011 07:45 PM
Just did the best upgrade ever Project Pony Pre-2005 V6 Mustang 10 03-11-2011 09:29 AM
help with new upgrade upton7 1996-2004 Mustang GT 0 03-28-2009 07:19 PM
Upgrade Stang02021 Pre-2005 V6 Mustang 34 02-05-2009 09:54 AM
3G Upgrade bluemustang 1979-1995 Mustang GT 11 06-06-2007 09:54 PM
11:40 AM
