abs light - Mustang Evolution
Old 05-09-2011, 04:29 PM   #1
znpzmustang's Avatar
abs light
so i have a 2000 v6 mustang, but i have an abs light on, the light has been on ever since i bought it and all the abs brakes look fine and they work fine but still the light is on. my car needs to be inspected next week, so is there anyone out there that have had that problm with the abs light being on? and if i cant get the light to go out will it pass the massachusetts inspection?
znpzmustang is offline   Reply With Quote
Old 05-10-2011, 09:46 AM   #2
wereKEV's Avatar
Re: abs light
is the brake fluid low if not maybe a bad conection on the sensor.
wereKEV is offline   Reply With Quote
Old 05-11-2011, 06:07 PM   #3
CHILE10_STANG's Avatar
Re: abs light
I have the same exact problem... This guy at ford thinks it could be some wire that went bad. I changed the abs module n light still on (bought it from a junk yard) so i dont kno what the problem could be =(
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 05-11-2011, 07:34 PM   #4
Re: abs light
no everything looks good its just the stupid light is on ans wont go out
Old 05-11-2011, 07:38 PM   #5
Re: abs light
like i know that the sensors and everything is ok but like im not sure what it could be im probley going to have to bring it to the dealer and see if they can detect something how much do they charge to check the light? if you know off hand
Old 05-12-2011, 07:12 AM   #6
Re: abs light
To check engine and inspection is like 130 if im not mistaken...
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-12-2011, 07:28 AM   #7
Re: abs light
check the sensors on each wheel
Old 05-12-2011, 08:35 AM   #8
Re: abs light
ugh! lol another bill and thanks, deffinatly going to have to bring it to the dealer if it fails inspection
Old 05-12-2011, 08:39 AM   #9
Re: abs light
i did, they are all fine, thats why i have no idea why it wont go out, we have even taken the battery out of the car after i checked the wheels and it still wont go out, to see if it might like reset it or something its deffinalty weird
Old 05-12-2011, 09:19 AM   #10
Re: abs light
I cant get mine to go off either =/
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-12-2011, 09:22 AM   #11
Re: abs light
How do you know they are fine? Did you just look to see if they were there? A wire could be broken at the connector, inside the insulation, sensor could just be flat bad but look fine on the outside.
Also, ABS should not cause you to fail inspection, at least it doesn't down here anyhow.
Old 05-12-2011, 10:17 AM   #12
wereKEV's Avatar
Re: abs light
Tell ford it is unsafe and they should fix it for free .
Old 05-12-2011, 10:41 AM   #13
Re: abs light
LOL YEA RIGHT!
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-12-2011, 10:44 AM   #14
wereKEV's Avatar
Re: abs light
Thought you could use a good laugh to get your mind off the problem you are having.
Abs light Nrooney3 1996-2004 Mustang GT 9 02-13-2011 07:51 PM
AbS light 2000StangLover Pre-2005 V6 Mustang 2 09-02-2008 01:44 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
ABS light slick Pre-2005 V6 Mustang 5 04-04-2008 11:31 AM
ABS light Zim 1979-1995 Mustang GT 9 10-13-2006 06:25 PM
05:25 AM
