Originally Posted by kickerofdoom I have a 2001 mustang v6 auto. Right now American muscle is having spend 100 get 15 off. I wanna get something to use the money off. Should I get a tlock but if I do I won't install till end of month. Some subframe connector won't install till later or some new front shocks cause I want to lower later. |
Well if you get a tlok you might as well get gears (200)..plus the install is 300-500+ depending on the shop. These 2 drivetrain components are probably the most bang for the buck mod you can do other than FI. You will need a tune afterwards to adjust for the gear change.
The subframe connectors are a good mod, they will stiffen the car up significantly and greatly reduce body roll in the corners.
Shocks and struts are a good thing to upgrade if you lower the car.
I say get the subframe connectors...those you can actually install right away and aren't overly expensive to have installed. (If you don't have access to a welder).
