I lowered my top the other day just fine (sounded a little weak though), when I tried putting it back up it wouldn't budge. I could still barely hear the top motor running (or hydrolic pump?) but it still wouldn't move. I put it back up manually with little resistance and tried using the motor again. It took a few seconds but it would come down again and it would even go back up (I could hear the motor trying to pull it each time but always took a few seconds to catch it). It seems to be able to bring it up again as long as its no more than halfway down.
I also noticed in between my left rear tire and fender there was some fluid leaking, seems like it either I have a hydrolic fluid leak or I just need more?
So anyone know what's wrong? Is the motor failing? Do I need more fluids?
Also if I need fluid, where do I put it(how do I get to it), and what fluid exactly would I need?
Thanks!
Thanks!
