01 hasnt been started in 2 years..help!! - Mustang Evolution
Old 05-14-2011, 09:19 PM   #1
okay i have a 2001 mustang that hasnt been started in about 2 years. i already drained the gas and put 5 gallons of fresh gas in. i pulled the plugs and sprayed each cylinder with fogging oil and put 6 new plugs in. i cranked it manually and everything seemed in fine working order..i tried turning the key and the engine cranks great...but will not start. i pulled some codes, i got P1233, p1516, and p0102, im not worried about the MAF code..i know thats not causing the no start..i checked the fuel shut off switch in the trunk and was down...i tried popping it up and had no luck starting the engine. it seems like its not getting any gas though. idk if the switch needs to be up or depressed...umm i can hear the fuel pump running when i turn the key on. i will check fel pressure tomorrow morning but is there something else? am i overlooking smething simple?? keep in mind that the car has sat in a garage for 2 years. thanks in advance for all the help!!!!
jwiseman is offline   Reply With Quote
Old 05-14-2011, 09:49 PM   #2
4.0
4.0's Avatar
Re: 01 hasnt been started in 2 years..help!!
well your on the right track for sure I believe the fuel shut off switch has to be pushed in for the pump to work and it pops out to shut off . another thing to check will be (spark )it will crank without spark but will not start you will need two people to check for that one to turn the key and one to look under the hood for spark . I dont know what the codes are by number but if you can tell me what the codes are I may be able to help you more . I hope this helps
4.0 is offline   Reply With Quote
Old 05-14-2011, 09:51 PM   #3
Spray a little choke cleaner down the throttle body. Then try and start it. Injectors may be stuck.
Alscobra is offline   Reply With Quote
Old 05-15-2011, 08:37 AM   #4
Beav's Avatar
Make sure nothing made a nest inside your exhaust... A friend of mine just found his pipes packed on his 69 XKE that he had sitting for a few years in his garage...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 05-15-2011, 08:45 AM   #5
Send a message via Skype™ to Texastboneking
of course it wont start. P1233 is a fuel pump offline code. your fuel pump is not working if you got this. p1516 this code has to do with the tps and electronic throttle control motor (if equipped). and p0102 is the mass airflow one. this one would let it start if it was the only code. but it would run really bad. you will need to fix the first two if you want it to start.
Texastboneking is offline   Reply With Quote
Old 05-15-2011, 09:06 AM   #6
I understand what the codes mean and I know which ones are keeping the stang from starting...I just need a little guidance as to getting the fuel pump back online and where to go from here...any assistance with that aspect would be grealty appreciated
Old 05-15-2011, 10:29 AM   #7
wereKEV's Avatar
There should be a fuel pump rest switch in the trunk .
wereKEV is offline   Reply With Quote
Old 05-15-2011, 10:35 AM   #8
The red button on the switch was depressed when I looked last night..tried popping it up..didn't work...pushed it back down, didn't work, disconnected the wires an hooked them back up to it...did not work. The p1233 code that everyone keeps saying fuel pump offline...actually on my scantool it says manufacturer air/fuel metering device...? Idk what it means...all. know is that its not getting fuel to the engine. I'm getting ready to chek fuel pressure right now just to be positive tho
Old 05-15-2011, 11:38 AM   #9
O yea by the way the car was wrecked...pretty bad front end collision..that's y the guy didn't start it for a couple years..
Old 05-15-2011, 11:44 AM   #10
honestly to me it sounds like some wires got chewed through by some animal. those codes dont just set. i would look for any damaged wires before replacing components. so you dont waste money
Old 05-15-2011, 11:45 AM   #11
99saleen87's Avatar
Definitely, happened to me as well, I didn't turn on my car for 10-11 months almost a year, and yes same symptoms as you, I could hear the pump, but still when I changed the fuel pump, she started right away! A good 95% sure, its the pump.....
99saleen87 is offline   Reply With Quote
Old 05-15-2011, 11:45 AM   #12
also might be a corroded relay keeping the pump off
Old 05-15-2011, 11:48 AM   #13
fuel pump might be running but might be full of bad fuel and trash and therefore aint pumping anything. sounds like you got you a project car lol
Old 05-15-2011, 11:48 AM   #14
Yea I suspected some wires too but can't find anything out of the ordinary except for a round male wire plug that's located under the pass side fender that is not connected to anything and I cannot find where it goes too. But I'm going to get a fuel pump right now and ill keep y'all posted and maybe we can get this figurd out!
Old 05-15-2011, 11:53 AM   #15
take a picture of the plug. i just replaced a simular motor and i know all the plug ins while they are still in my head
Old 05-15-2011, 02:00 PM   #16
Jamesgt08's Avatar
Hopefully that plug doesnt go to ur module that controls ur fuel pump. That is located under the passenger fender.
Jamesgt08 is offline   Reply With Quote
Old 05-15-2011, 05:50 PM   #17
Well...out of the 3 part stores close to me, nobody has a fuel pump till tomorrow after noon. I came home and pulled the fuel filter and turned the key to on position...no fuel came out of the line..I tried cranking the engine...same thing..so either the fuel pump is not getting power or the fuel pump is bad. And to texastboneking..I'm gona post a pic of that connector real quick its the round plug I'm holding to the left of the pic
Old 05-15-2011, 05:53 PM   #18
It will not let me post a pic from my phone and my laptop is out of comission...u have an email address I could send the pic too?? That would be super helpfull and greatly appreciated! Thanks
Old 05-16-2011, 10:28 AM   #19
wereKEV's Avatar
If it was in an accident some of the wiring is probably damaged might have to rewire a few things.
Old 05-16-2011, 10:42 AM   #20
There's not a single wire that has been damaged. I think I've narrowed it down to the CCRM. If only I knew which wire on the ccrm plug is for the fuel pump power, I could take a test light to it. Screw it I guess ill just go buy a new ccrm and see if that solves the problem
Old 05-16-2011, 10:44 AM   #21
Is there another fuel pump relay somewhere?? Cuz autozone is showing that there is but I cannot locate it for the life of me!
Old 05-16-2011, 11:24 AM   #22
It would be in the relay and fuse box under the hood. If there is one
Old 05-16-2011, 11:27 AM   #23
The only thing in there is a tiny 20 amp fuse. You cannot replace the relay that's inside the ccrm can u? U have to buy the whole unit, correct?
Old 05-16-2011, 11:53 AM   #24
Jamesgt08's Avatar
Yea there a fuse in the fuse box jnder hood. And yes you will have to replace the whole ccrm. I was having the same problem but it was my fuel pump that went bad.
Old 05-16-2011, 07:00 PM   #25
wereKEV's Avatar
I came out from the store when I had my 98 GT and it wouldn't start iy ended up being a abd pump.
Old 05-16-2011, 07:12 PM   #26
Okay guys one more question lol....I took a test light to the fuel pump relay wires comming out of the ccrm and theirs juice, so I took the test light to the fuel pump control module in the trunk and theirs juice to that too, theirs also power going to the inertia switch....so in my opinion it HASSS to be the fuel pump...any other opinions?
Old 05-16-2011, 07:14 PM   #27
That sounds about right. If there is power and ground at the pump, the pump should run.
Old 05-16-2011, 07:17 PM   #28
Jamesgt08's Avatar
Yea im sure its the pump.
Old 05-17-2011, 10:32 AM   #29
wereKEV's Avatar
yeah it sounds like the pump I changed one on my 98 and it was a pain in the bitt good luck.
Old 05-17-2011, 12:16 PM   #30
Jamesgt08's Avatar
It isnt that hard. I did mine on my 2000 which i the same pump as your 01. I did mine in about an hour.
Old 05-17-2011, 09:27 PM   #31
Greg687's Avatar
Region: New Mexico
pump filter probably has varnish on it from the bad gas. you MIGHT be able to salvage it with carb cleaner, but you have to take it off anyway, so it' s best to replace it.
Greg687 is offline   Reply With Quote
Old 05-17-2011, 09:59 PM   #32
Thanks for all the help guys, I put a new fuel pump in justt now and she started right up! Were idling a lil rough but I think a short test drive should clear that right up! Again thanks for all of the help resolving my problem. =)
Anniversary 30 Years English Paul General Mustang Discussion 11 06-24-2009 12:20 PM
X-mas or New years sledgehammer The Bar 11 01-10-2008 07:38 AM
40 years later: MarkuzLS1 The Bar 3 06-06-2007 11:50 AM
2 years from now what will you be driving? sonic04edge The Bar 46 03-19-2005 11:03 PM
Well after nearly 4 years.. n8r The Bar 10 02-09-2004 10:00 AM
06:24 AM
