what is this? - Mustang Evolution
Old 05-17-2011, 01:37 AM   #1
blackonblack's Avatar
what is this?
Faq
does it really add that much or is it just another one of those things...i do see its only good in bursts of 30 seconds but it seems pretty cool
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 05-17-2011, 06:44 AM   #2
shaqfu's Avatar
Re: what is this?
that looks pretty sketchy
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 05-17-2011, 06:48 AM   #3
kickerofdoom's Avatar
Doesn't work gets in the way of air getting into the car so makes less horsepower
Old 05-17-2011, 08:13 AM   #4
Re: what is this?
110% worthless, crappy rip off dont waste your money/time on a rip off.
Old 05-17-2011, 10:19 AM   #5
Titus Wadicus
svtlx's Avatar
Re: what is this?
at least it was packaged well...for strong delivery..lmao!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-17-2011, 10:23 AM   #6
Remember no such thing as cheap power. Plan out what u wanna do and go for it. With some stuff I'm sure u can make the car fast
Old 05-17-2011, 10:24 AM   #7
Las0mbra's Avatar
I've seen those before... I think technically, to produce enough boost, they have to have like 200 volts... The alternator will give it 14.4...
Old 05-17-2011, 10:32 AM   #8
Las0mbra's Avatar
Look at this...
http://en.m.wikipedia.org/wiki/Hybrid_turbocharger
States that even a high efficiency electric turbo at 120,000rpm produces about 9hp on a small engine... And about 35hp on a larger car. Not the most powerful I'd say. And the one you have there would probably just be a restriction anyways. And even one of the worst things wrong with these... If they break, those are pieces of plastic and metal going into your engine.
Old 05-17-2011, 10:44 AM   #9
wereKEV's Avatar
Re: what is this?
thats a wannabe super charger it's better to save up for a real one .
wereKEV is offline   Reply With Quote
Old 05-17-2011, 12:04 PM   #10
Re: what is this?
yeah thought so. sounded to me to be like that thing that spins air in your CAI that also doesnt do a thing
2004 3.9L v6
Old 05-17-2011, 03:43 PM   #11
Las0mbra's Avatar
Read this, it'll tell you all about these
http://www.wildweasel.ca/HowTo/Auto/eturbo.aspx
Old 05-17-2011, 09:21 PM   #12
Re: what is this?
The Turbonator!!!
Old 05-18-2011, 11:49 AM   #13
wereKEV's Avatar
Re: what is this?
The sad thing is there are people stupid enough to buy that crap.
Old 05-18-2011, 05:57 PM   #14
Camo1967Mustang's Avatar
Re: what is this?
Yup
Im glad I know better
Thats just craziness
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
04:13 AM
