2000 Convert Window Issue - Mustang Evolution
Old 05-20-2011, 12:14 AM   #1
All right, I've had driver side window issues before regarding my 2000 convert (power windows) where the window falls out of the bracket/guide. Couple days ago the same thing, so I popped the panel off today and found that the window is no longer glued into the rear bracket and had actually popped out of the slot on the bracket. I managed to get it back in without much effort but now the window won't work properly.
If the window is sitting flat in the bracket and the window is all the way up (which should be how it sits as it lines up perfectly with the door shut), if I try to lower the window it jams about 4 inches down on the back side, in order to get it down I have to lift the back side of the window and then it will continue to roll down. On the way up there are some issues too where it doesn't seem to follow the door seal of the quarter window. After a few rides up and down the rear part again starts to pry itself out of it's bracket. SO, with that said, can this be fixed with some adhesive or am I looking at something much more costly? And one other thing, is the rear bracket supposed to be able to pivot or turn slightly? Cause it does. ANY help would be appreciated.
CjL716 is offline   Reply With Quote
Old 05-20-2011, 08:53 AM   #2
Re: 2000 Convert Window Issue
this is probably not related but the little rubber door jam piece right there where the black trim and the door jam meet has a metal piece in it, it can wear and the window can get hung up on the metal~ you can make sure that part is not worn/bad. Quick easy thing to look at.
Old 05-20-2011, 12:35 PM   #3
That does seem to be about the area where it would be getting hung up however I can't tell if it is or not. Pulling back the rubber I can see the piece you're talking about (if that's what I think it is), but there isn't any wear on it, doesn't mean it's not hitting it but can't say for sure. Thanks for the advice.
Old 05-20-2011, 12:53 PM   #4
the window could be to far forward. You can pull out two of the little push pins on that little piece I told you about earlier (one side wont come off but the other will, the side that goes on the interior panel pulls out easy) then pull it out of the way see if it moves ore
Old 05-21-2011, 12:57 PM   #5
Yep, Sure enough the rear portion of the window is hitting that metal piece in there. So how do I go about fixing this? I can get the window to descend if I pull the rear potion up slightly out of the bracket, then it has enough clearance room but it also starts to come out of the bracket. I have a feeling I'm going to end up resealing the bracket but how should I arrange the window in there is the question.
2000, window piller remove for paint Renegade 800 Mustang Audio & Video 1 01-25-2011 01:34 PM
2000 V6 clutch/shifting issue audio75 Pre-2005 V6 Mustang 10 07-31-2010 11:41 PM
Redueing My 94 Gt Convert bobt 1979-1995 Mustang GT 4 06-25-2007 05:30 PM
Wats Needed To Convert 99 V6 2 4.6 V8? scrimsmustang 1996-2004 Mustang GT 19 01-03-2005 04:56 PM
How do I convert to 4x4? ItWouldAppearSo Pre-2005 V6 Mustang 23 10-03-2003 07:51 PM
10:07 PM
